Ditting 807 Lab Sweet user experience - Page 8
There was a few things:jb-0101 wrote:Awesome review!! Thanks so much.
Can you give me any more info on what the Ditting guy said about 804 vs 807? Was it more around build type stuff; ie quality, workflow, retention, etc or was it about grind quality and results in the cup?
The mechanism of the burr carriers and the adjustment which apparently have a significantly improved design and is much sturdier.
The design of the grinding chamber and chute to reduce retention.
There was the way air circulates and the added fans for cooling.
The placement of components have improved accessibily for maintenance and also the removal of the hopper
The dial has been improved for more precision during adjustment
Overall quality of the internal components have been significantly improved apparently, and the guy said they believe it will be even more durable than the 804
oh man, seems like my next grinder is the 807 Lab Sweet from the 804 Lab Sweet
honestly I am totally happy with my 804LS and which I had gotten the 807LS, but i got a deal so it was worth the trade off, but I do think the 807LS is just stunning. I switch it was shorter and maybe a 3d printed hopper can solve that, but the rest of the grinder is awesome. Happy you have no regrets!
Curious. What is your 807 Sweet retention on average? I have a KR804 with Sweet burrs. I lose .3 to .2g, usually .3g since I mostly use Ethiopian coffee, per ~24g ground.Porcupine wrote:
This thread convinced me to pre-order one
Will be a while until it arrives (est September -October) as all stock is out here in my country according the official distributor here
Interestingly they said that the 807 are made in Hemro factory in Germany, not in Ditting factory in Swiss.
LMWDP #668
Yes I was told production was moved to a new factory in Germany
Is this the finest setting from the 807 lab sweet? I have the grinder since few months and no way I can get close to grind so fine. Light roast are flowing in 15 seconds with 1:3 brew ratio, +1g overdosing the basket and pump running at 6bar. I did the zero setting and burrs are slightly touching at the 1 mark (scale start at 1)mtbizzle wrote:I'm not sure what the issue is on your end, this is definitely not an issue I have. I'd say my lab sweet grinds fine enough that, if you showed me finer grinds, they'd look indistinguishable, it's powder, flour to the point where I'm not sure I could pick up on further degrees of fine. It won't even declump. image
Any idea?
Have you checked alignment? The more precisely aligned, the finer you can grind.
Aligned today, situation improved but with light roast coffe roasted mid July it still flows quickly but the taste is good despite bridging all the standard rules.
Shot details are the following:
18g vst basket
19g in
53g out
Time 18"
Machine pressure 5.5bar
Flow rate at 260g per 30"
Extraction yields at 24.6%
Still fast following the first drop after 4 seconds but taste very good! I'll play with different fresher coffee
18g vst basket
19g in
53g out
Time 18"
What were your steps in aligning. Marker test?Mixpix wrote:Aligned today,
I am thinking about trying on a KR804 with sweet burrs, next time I clean them.
