Weber EG-1 v2 Grind Settings (SSP Ultra DB-2) - Page 3
The Ultras are tricky but definitely usable for espresso. Seasoning helps a lot with both feeding and results in cup IMO, and higher RPM is a must. I use 700 for filter, and even for espresso when I use the Core burrs, but usually go up to 1500 for espresso with the Ultras.
OK, after some more testing, I can avoid the locking by pouring the beans slowly. But I am 3 points away from full lock and still grinding too course (a high density bean). In fairness, I am afraid to go finer, I dont want to damage the burrs.
Any advice?
Any advice?
For light roasts I am grinding at 5.5 (full lock is about 2.8 now after seasoning with a few kg).Just got my EG-1, swapped the Ultra burrs on immediately and getting the following:
- Full lock = 3
- Espresso = 6.5 - 7.0
- Aeropress = 9-11 (still experimenting, but i prefer the higher range, might try some at 12 to 13)
I have had the grinder lock on me two times, but i am grinding light roast at 700rpm. Slightly increasing the grind +5 notches and pulsing the motor, then going back down to my set point fixed it each time.
Still playing around a lot with the ultra burrs, and unsure about how i like them for espresso.
The back to back results with filter coffee are huge though and im very happy with them
Just got hit with CA Use Tax nearly a year after taking deliver. I had confused the import duties with use tax, so thought my financial obligations were done. YIKES!
My grind settings are in the same ballpark as others have posted on here. Below about 700 rpm I have to pour the beans slowly to avoid burr lock, been satisfied with results at 850 rpm. I also dialed back the pressure on my espresso machine a couple bars.
That's weird. I can go down to 300rpm for espresso or pourover with nordic roasts and just dump the beans in at once with a running motor. I've never had my EG-1 V1 stall in 3,5 years of use and running 80KG of light roasted coffe through it.
I'm not sure how much the electronics changed between V1 and V2, but it could be because you are in EU running 220V vs. those of us in the US running at 110V.
Nick
Nick
Just a small contribution to this grinder stalling thing.
Running at 230V I have locked up grinder using the core burrs at espresso grind a handful of times. A gentle pour is how I live my way around this.
I have not locked the Ultra Burrs at espresso grind however. This is 10 months and 10+ KG into each burrset.
