Use Eureka Olympus without the hopper?
I am trying to make room for a Eureka Olympus that I am considering. I am not looking to use the blow through system. Even with the smaller bean hopper, it would be to tall for where I need it to be.
Does anyone use the Olympus without the bean hopper(single dosing)? Any drawbacks to doing that if I just place the hopper lid over the hole so beans don't fly out?
It'll work. A friend of mine did it when he bought my Olympus.
Wow, I am surprised I did not see that video in my searches.
I wish I knew how much coffee was that in the puck after he grinded(at 19 seconds in the video). Any ideas how much it could of been?
Also, I've been studying the video and I can't help but wonder if there are few beans left ungrounded and he stopped grinding to soon? On the first pass that is
He normally uses 18gr. He did some more testing and retention was close to 0.2gr. It's possible but takes a while to grind this way. I just purged 0.2s (3gr) before every session and ground 18gr in 3.2s.
In the video it looks like he grinded and filled the portafilter about 1/3 full. Then, with the blow system it filled the portafilter the rest of 2/3. That would be a lot of retention...about 12 grams of retention. Am I looking at it correctly?
That's a totally wrong and useless way of measuring retention.
Is this with single dosing? For single dosing, I thought you mentioned it was in the ballpark of 16 seconds for this grinder to grind around 18 grams?erik82 wrote: ... and ground 18gr in 3.2s.
That's with hopper use like I used it. It's impossible to singledose in that amount of time with any grinder.
It's certainly doable with vertical burrs.
For mine, it grinds 18g single dose in about 5s
