SSP Lab Sweet 64mm - Page 42
I have blind cupped before, with P64 rpm 7 and 2.
The 7 was not bright, but was good, with an enhanced sweetness.
The 2 was clear, but not sweet, and unpleasant tastes were noticeable in their place.
This result was not what I expected.
The uniquely shaped cast Burr may tend to be different from other SSP Burrs.
With so few specimens, we encourage you to give them a try too.
Thanks for your reply. No I haven't replaced the stock declumper. Its a brand new df64 though and i heard they improved the stock declumper so i did not look to modify it. I also have another quite new df64 with ssp unimodals that produced coffee grinds that I really like the taste of and which also has the stock declumper. Do you believe thta the ssp cast steel burrs produce a lot more fines than the unimodal burrs? If this is happening, why do some report that after grinding a lot of coffee beans through their cast steel burrs, the bitterness disappears?
LMWDP #729
it is possible due to the different geometry, i have replace the declumper before i use the LS. i didn't notice the bitter after taste even with the un seasoned burr. but the sweetness is day and night compared to the stock itamill burr.Primacog wrote:Thanks for your reply. No I haven't replaced the stock declumper. Its a brand new df64 though and i heard they improved the stock declumper so i did not look to modify it. I also have another quite new df64 with ssp unimodals that produced coffee grinds that I really like the taste of and which also has the stock declumper. Do you believe thta the ssp cast steel burrs produce a lot more fines than the unimodal burrs? If this is happening, why do some report that after grinding a lot of coffee beans through their cast steel burrs, the bitterness disappears?
fineline wrote:I have blind cupped before, with P64 rpm 7 and 2.
wow this is interesting, lower speed does not always equal to better. i suspect that to. some how i like 700rpm better than 600rpm.
i will try playing some more. thank you fineline for the info. i will post my experience once i explore further about LS and rpm.
I am also in the seasoning phase of the Cast burrs, so far nothing really impressive. Coming after the SSP HU for more than one year, I could feel the loss in clarity but the increase in overall sweetness. Can't hit any special note or flavor so far, just getting a mellow-ish espresso. I didn't notice any bitterness but I use the improved DF64 chute without declumper.
Now the question for the more advanced users of these burrs is - how long until you noticed a change in the cup? Should I check again the alignment? Can that influence the result so significantly?
Also, any changes in your recipe / extraction times?
Cheers!
CM
Cheers!
CM
Some have gotten away with 10kg others needed like 15-20kg
It won't start performing before it's well seasoned a general issue with cast, it needs to be well seasoned before making judgments... but if one is more into high clarity abruptly transitions of high clarity burrs I'm afraid cast burrs will never be down those peoples alley.
im on the opinion that these crushing burrs on the cv needs slight deburring and smoothening, hence the need for long break in.
once done there will be less fines and more even grind particles, hence better cups without the bitter aftertaste.
perhaps anyone who tested before and after break in can comment. i didnt do the 2kg coffee dumps, but i did do inital taste comparison, and the bitterness was obvious back then.
Yes you have a bitterness at higher extraction until the burrs settled in, the flavour also improves as the burrs get more and more seasoned, the burrs aren't performing well under 2kg seasoning, after 2kg it's starts getting better as it season... The report says past 15-20kg it delivers amazing results... but that's a lot of coffee and bit of waste.
I have so far put less than 250g through the cast burrs and the bitter aftertaste has mostly faded away. The difference with my conical grinder is not as stark as with the ssp unimodal burrs but I am liking the cast burrs more than my conicals for lighter roasts so far. I suspect it is still going to change quite a lot more before it settles down fully.
LMWDP #729
I've put a good 5kg though my burrs and realigned them a few weeks ago. For me the main frustration is not being able to grind fine enough. I'm literally at burrs touching and can barely reach 25s on an 18g 1:2 shot with Squaremile's Inza beans. Don't know what to do anymore...
