Repository of electrical measurements from grinders
buckersss
#1: Post by buckersss »
Curious if people who have a home multi-meter are willing to post the power draw and or current draw of their grinders. ideally looking for north american 60Hz 110-120v measurements.
i find real life performance can deviate from manufacturers specs and reseller specs. i understand too that certification isnt always reflective of actual performance.
ideally im curious about power/current draw after full spin up - no beans in the chamber. always open to more information if you want to post under load/while grinding too. expect that it would be valuable to post how roasted your beans are if you want to contribute measurements under load.
i thought this may be valuable for many people, so ill say measurements from any and all grinders are welcome.
i appreciate that comparing grinders with ac motors and dc motors is apples and orange. Also appreciate that efficiency can drastically effect what gets absorbed by the motor. all else being equal, im looking to validate that which has been advertised by the manufacturer.
to kick it off id forever be appreciative of anyone willing to take and post measurements for the atom 75 and mahlkonig k30. Ty
AssafL
#2: Post by AssafL »
Whoa...
Measuring current on a mains connected equipment, sometimes with a chopper and/or switched mode power supply, is not a "home" multimeter thing.
You need an RMS meter, that has an Amp range that will not fry the fuse (startup current may be large). Or better a clamp and an exposed wire section (or loops). You need to multiply voltage by current.
And to measure current you have to connect it inline (so buy a extender, open the wire, solder....).
I have some DC measurements for a Versalab at Versalab M3 vs. Others.
cafeIKE
Supporter ★
#3: Post by cafeIKE »
I have 4 grinders, the tools and the knowledge how to do it
I've measured just about every other espresso related parameter, but for the life of me can't think why I would care.
BaristaBoy E61
#4: Post by BaristaBoy E61 »
AssafL wrote:You need an RMS meter, that has an Amp range that will not fry the fuse (startup current may be large). Or better a clamp and an exposed wire section (or loops). You need to multiply voltage by current.
Here are my 'measurements' of a Mahlkonig K30 Vario grinder with a Fluke 'True RMS' multimeter done as Assaf has mentioned above with an inductive coupler on 1-side of the AC line measuring millivolts AC multiplied AC line voltage.
Meter set to capture 100ms peak, min. & max.
Peak measured 1,048.32 watts
Avg. measured 851.76 watts
For what it's worth...
AssafL
#5: Post by AssafL »
BaristaBoy E61 wrote:Here are my 'measurements' with a Fluke 'True RMS' multimeter done as Assaf has mentioned above with an inductive coupler on 1-side of the AC line measuring millivolts AC multiplied AC line voltage.
I think he wanted no beans (sort of iron losses in the core).
1048W would hopefully be with beans....
BaristaBoy E61
#6: Post by BaristaBoy E61 » replying to AssafL »
No beans 100ms peak. Seems rather high I thought... But it is in-rush.
buckersss (original poster)
#7: Post by buckersss (original poster) »
AssafL wrote:Whoa...
I mean there is more than 1 way to skin a cat. Those are great, but I'm not advocating anybody perform any work they aren't confident in or do anything without taking the right safety precautions. I'd be over the moon with a simple power reading from an inline killawatt meter.
BaristaBoy E61 wrote:Here are my 'measurements' of a Mahlkonig K30 Vario grinder with a Fluke 'True RMS' multimeter done as Assaf has mentioned above with an inductive coupler on 1-side of the AC line measuring millivolts AC multiplied AC line voltage.
Amazing! Thank you. I expected it to be pretty spot on but that's impressive. I expect it'd draw even more when grinding. Much appreciated.
yakster
#8: Post by yakster »
A Kill-A-Watt might be an easier way to measure this.
-Chris
LMWDP # 272
#9: Post by buckersss (original poster) »
Welp I don't think this topic got much traction. Never the less, I recently bought an atom pro (North American version) and took some measurements. I figured I'd share them. I just used a simple kill-a-watt.
After turning on the grinder and waiting about 5-10 seconds until full spin up, the atom pro draws around 750-775 watts. When crushing some medium roasted beans, it jumped very briefly to 1050 watts - but probably averaged closer to 900 watts throughout the grind cycle.
The atom pro spec sheet from eureka is next to useless.
The atom 75 spec sheet from eureka claims a 10 amp draw at 110/120v.
The bottom label on my atom pro shows the unit draws 8 amps. I think (not certain) this is the same as the label on the bottom of the atom 75 and the Olympus 75.
There is a video about the atom pro produced by espresso coffee shop. In the video they interview a eureka engineer who highlights the features of the atom pro. IIRC the eureka engineer mentions that the atom pro has an upgraded motor when compared to the atom 75. I doubt this is true.
I got frustrated when researching grinders in general, as I couldn't seem to obtain accurate information. With that said, the motor on my atom pro seems plenty strong and this is a gorgeous grinder.
AssafL
#10: Post by AssafL »
Good grief....
Why do these grinders take 700W for unloaded spinning? Are the burrs touching? Is the spindle locked???
700W is ALOT to spin a free running motor. A bit of steel losses, a bit of mechanical friction in the gear and bearings. 10W-20W maybe... If there is a gear box 20-50W depending on how many stages and how good it was.
I can't measure it now but in the graph below you can see the current and voltage. The grinding in the hump in the middle (roughly 2.8A x 90V or about 250W). But without load it is around 0.5A at 90V or about 45W. Also high and consists of the steel losses, bearings, and mainly the timing belt that rotates the burr spindle.
userpix/7536_versalab_bodine_0866_some_ ... _point.jpg
I am tempted to say that the kill-a-watt is giving incorrect readings. If that 750W would go into friction it would cause massive heating (like starting a fire with a piece of wood).
