Question for owners / users of electric variable speed grinders.
redbone
#1: Post by redbone » Oct 09, 2019, 8:29 am
1) How many owners / users of variable speed grinders change speeds on a regular basis? Regular as in per day / bag or coffee type.
2) If you don't change speeds have you settled on an ideal speed and what is that speed?
Semper discens.
Rob
LMWDP #549
Quester
#2: Post by Quester » replying to redbone » Oct 09, 2019, 9:19 am
EG-1 600 rpm
I bump it up or down to fine tune when I want to tweak more than 1 step on the grind adjustment ring provides.
[creative nickname]
#3: Post by [creative nickname] » Oct 09, 2019, 10:33 am
EG-1, 500RPM. I keep it fixed here and rarely bother to change it. I did some blinded comparisons early on and found that, when dialed in for the same flow rate, slower grinding speeds generally tasted better, so I set it slow and kept it there.
LMWDP #435
Chert
#4: Post by Chert » Oct 09, 2019, 10:59 am
EG-1
I have mine currently at 300 for espresso and I have been using between there and 450, but I control flow with the lever and change coffees so often that I don't usually manage to settle on a particular setting of RPM or grind before moving on to another coffee. Maybe I should try to be more systematic.
Only for batch brews do I crank the RPM for efficiency reasons. The spout spews a bit more grinds about at higher RPM so the slower speeds are a bit tidier, too.
Peppersass
#5: Post by Peppersass » Oct 09, 2019, 12:20 pm
Monolith Flat with SSP burrs.
After experimenting with various speeds, I settled on 450 RPM. The only exception has been for very, very light roasts where I couldn't grind fine enough to get the flow rate I wanted. Increasing RPM for those coffees solves the problem.
I also bump speed to the max 800 RPM when flushing the grinder. Sometimes this results in a tad more of the very minimal retained grinds coming out.
LBIespresso
#6: Post by LBIespresso » Oct 09, 2019, 1:18 pm
Please disregard my earlier posts in other threads about grid speed ;-) Monolith Flat SSP I have settled on 500 and rarely change it. I feel that other ways of tweaking flow rate are sufficient. My life is easier now that I have settled on fewer variables. Plus Denis says 450-550 is ideal and saw no benefit from going slower. Although I did see a difference and was able to use grind speed to impact flow rate it just wasn't the best method for me.
LMWDP #580
pcrussell50
#7: Post by pcrussell50 » Oct 09, 2019, 1:38 pm
-Monolith FlatSSP
550 rpm as per Denis guidance for the SSP burrs. I also do what Dick does and speed it up to sling some strays out.
-LWW HG-1 motorized 83mm conical
80 rpm
I consider these to be middle of the road settings. I rarely stray from these though I have noted Dick's observation that he can grind finer with higher rpm, for future use if necessary.
-Peter
LMWDP #553
baldheadracing
#8: Post by baldheadracing » Oct 09, 2019, 1:53 pm
redbone wrote:1) How many owners / users of variable speed grinders change speeds on a regular basis? Regular as in per day / bag or coffee type.
1. I don't.
2. On the Apex, the design/target burr speed is 500rpm. In the range of 400rpm-600rpm, I preferred the taste from lower rpms, so I aim for 450-500rpm. (400rpm stalls too often for me.)
What I'm interested in is my worst espresso being fantastic - James Hoffmann
