Performance Question - Kafatek Monolith Flat vs Mazzer Major with SSP
I presently have a DE1PRO v1.1 and a Compak K10, which I think has been great for most roasts. However, I know a flat burr set up is necessary to get the most out of light roasts, of which I've been buying more and more. That said, I have a decommissioned, unassembled Mazzer Major downstairs (doserless mod) that I could put together with new SSP burrs. Is this the preferred avenue to perhaps buying a Monolith Flat? Does anyone have any insight as to whether a well aligned Major w/SSP produces a similarly consistent grind to a Monolith?
I doubt you would see too much of a difference in the cup...the major difference would be the workflow of a single dosing grinder vs a commercial grinder (assuming you single dose).
You should talk to Jake.
He has access to Monoliths. And he personally owns a Super Jolly with SSP burrs that he also precision aligned. He has lots of insights into your question.
-Peter
-Peter
LMWDP #553
Haskens wrote:I doubt you would see too much of a difference in the cup...the major difference would be the workflow of a single dosing grinder vs a commercial grinder (assuming you single dose).
I couldn't agree more.
can you point to a thread where he explained what he did? I have a micrometer dial yet don;t think it's useful as the teeth of the burrs make it wobble.pcrussell50 wrote:You should talk to Jake.
-Peter
I checked the smooth plane inside the burrs with it and found it to be true to a very tight spec.
LMWDP #483
- Supporter ★
For dark roasts, there will be little difference. For light roasts, Flat and MAX will be better.
Jake will be a good resource, as he has experience with Monoliths and other smaller burr aligned flat grinders
- Supporter ★
Alignment, burr size and design.
Unless you are drinking mostly well developed light roasts, and want to pull them at brew ratios <1:2.5, it may not be a difference that matters to you.
For the coffees that don't benefit from large, flat, hyper aligned grinder, I will very often use a MC3 instead.
Wouldn't 83mm burrs be larger than the Monolith Flat or is there something I'm missing?
- Supporter ★
No. You are correct there, but my comments were inclusive of MAX.
