Orphan Espresso LIDO E First Impressions - Page 7
- Supporter ❤
please do not take it entirely apart.andpgud wrote:Got my lido ET
How should I adjust it for my Mcal leva and how do I adjust it?
So is LIDO that good for french press regarding quality and mobility (size)? As far as I understand there is no difference between LIDO grinders in quality.
I am looking for a new grinder to replace my Hario Slim at work.
- Balthazar_B
I use a Lido 3 at work for press brewing, and it is perfectly excellent. In my case, it replaced a Porlex I'd been using, and the difference in speed, ease, and output quality is night and day.
- John
LMWDP # 577
LMWDP # 577
Does anyone know why when I try to lock my locking ring, my adjustment rings turns too? It seems hard to fix a location for a grind. I got the Lido for a couple of weeks now, does it need to break in or anything? Thanks.
- dominico (original poster)
It takes a little finesse and adjustment to get the hang of it: what I normally do is put the hopper opening against my chest and slide the adjustment ring just a little farther than I actually want it,
then I slide the locking ring until it is up against the adjustment ring: hold the locking ring in place and tighten the adjustment ring into it. After a few adjustments it becomes second nature to tighten to the spot you want.
https://bit.ly/3N1bhPR
- MB
I recently switched from the Hario Slim at work to the Lido E; only, I use it for espresso grind in a tamped, heavy pushed AeroPress technique. The first taste was noticeably smoother with better flavor in comparison. The shortened time grinding was a pleasure.SuchBrewSoCoffee wrote:So is LIDO that good for french press regarding quality and mobility (size)? As far as I understand there is no difference between LIDO grinders in quality.
LMWDP #472
