Orphan Espresso LIDO 3 first impressions - Page 7
- dominico
Glad to hear it! Makes for an easy choice for me.
https://bit.ly/3N1bhPR
- Bob_McBob
I'm also getting the shaft rubbing described by a few other HB members. As Rich (OldNuc) pointed out, it's unrelated to burr rub, which I confirmed by removing the lower burr. It's not something I'm able to reproduce with my LIDO 2. It's not just a matter of a rubbing sound; it ranges from a slight rubbing sound, to enough friction to stop the handle spinning freely, to a very obvious misalignment that requires force to turn the handle. I haven't been able to identify any sequence of adjustments that avoids it completely, and re-locking the rings will often improve or eliminate it. Rather bothersome since I love the new design otherwise.
Also, is it acceptable for the breaking area of the burr to be chewed up like this?
Chris
It's certainly not uncommon and I've seem much worse than that on brand new much more expensive conical burrs.Bob_McBob wrote:Also, is it acceptable for the breaking area of the burr to be chewed up like this?
Ira
- baldheadracing
I was wondering if removing the nylon slip ring would reduce the incidence of 'shaft rub' for those who have experienced it.
- Bob_McBob
I had the same thought. I tried removing it and noticed a significant drop in the rate of the really bad shaft alignments, but the problem still persisted. I reinstalled it and the shaft alignment has been behaving better, but it will still randomly start binding after moving freely for a number of adjustments.
I should probably note that my LIDO 3 also arrived with the adjustment rings unlocked and the hopper screws really loose.
Chris
To get these grinders aligned to cancel out or minimize all of the various manufacturing tolerances is, as I have said before, not a trivial task. It can be done though. There is no practical way to make the lower bearing carrier ring with a zero clearance so this will be a feature. Careful tweaking will minimize it though.
- Paul_Pratt
I picked up 2 and 3 at SCAA and have used them everyday now for drip and espresso. They are fabulous machines and the quality between them and say Hario, Porlex etc..is off the scale. Doug and Barb deserve some huge credit for reinventing hand grinders from, let's face it, quite poor mediocre tools that produce brown lumps, to something very precise and capable of great things that will perform for decades and at decent prices.
- drgary
+1
I still see people going for budget hand grinders and think they're missing a lot without a LIDO, any version. Now that there are locking gaskets for the ring adjustments and catch jar, the setting holds, the jar stays put and it's a reliable machine I use daily for office coffee that rivals what I get from my Bunn with Ditting burrs.
LMWDP#308
LMWDP#308
The normal manufacturing tolerances show up when either of these grinders are adjusted to a point way past where any useful ground coffee is produced. When operated as designed to produces good Turkish grind or coarser they do an amazingly good job.
- Shenrei
Agree with all of the above - the Lidos are amazing. They might need a bit of mechanical finesse but if you like manual grinding and admire the design, it's pretty enjoyable to put everything together.
I was able to minimize a lot of the intermittent rubbing with re-aligning the Lido 3 a bit using Doug's video, some things that were mentioned here, and a bit of improv on my end. Would like to do this on the Lido 2 as well to see if it helps with the free spin but don't really feel the need to as the grind output and resulting cups are stellar.
- Tim
