Orphan Espresso Apex Grinder - Page 54
Looking forward to the fennel, it looks great. I'm always worried the auger spring is going to break on me like it has with others.
Are Barb and Doug already sendind them?redexjames wrote:<image>
<image>
<image>
7/6
I send mail to Barb and Doug.
And I get this today.
I come from Taiwan.
I come from Taiwan.
I just installed the funnel (thanks, Barb ). It seems to be easier and faster to grind than before (not that it's ever hard and slow before though). The last bean or two have some trouble getting into the burrs, a very slow back and forth paddling of the spin handle does the trick.
Ethan
LMWDP#611
LMWDP#611
- instantkamera
I've read most of the replies in here over the last few months - not all in one sitting. I'm not convinced that this grinds fine enough for the smaller/faster brews that I make. I pretty much exclusively use smaller drippers (v60-01, kalita 155, etc) with doses <15g (13g is my go-to sweet spot); is anyone in here using this on the regular for these sorts of brews?
Thanks.
Thanks.
it grinds pretty fine, imo. I use a V60, 23 grams 45 second bloom and it's done at 2:30 and I'm at the 8th or 9th click. For a V60 this will grind finer than what you'll need.
- instantkamera
Thanks for the reply.
If you could replicate that recipe - roughly - with a 12-13g dose and report back your findings I'd be ever so grateful. Your dose is nearly twice what I normally use. I don't really have context on how much 8-9 clicks is in terms of coarseness change (and Im assuming 0 is some limit or other - burr lock or physical setting limitation).
I use v.60 01 paper in 02 dripper, 15/255gr, 3 click from finest blooming 45s, ending 2:00 - 2:10, other than less fines, uniformity grind size, the major benefit with Apex were the flow rate really fast, other hand grinder we are thinking how to increase the flow rate, Apex the other way...but there some beans with very slow drowning especially with kalia wave, V.60 I never have any problem with the flow rate
It'll grind fine enough, the only thing is I don't know if I'd want to hand grind on it at its finest settings... I have zero issues grinding it where I do, but I remember trying to grind on the finest settings with a light roast bean and it wasn't much fun, that was also be for I bolted to the chopping block.
- instantkamera
Thanks for the replies folks. That's certainly something to think about (time to grind at finer settings) but also the dose would be lower so maybe there's some offset there.
