Option-O Mizen 64mm Omni burrs for Lagom P64 - Page 12
how do these compare to your old burrs (which ones) ?Bunkmil wrote:I have a first generation p64 and I have no issue with my Mizen. They sent some shims because the burrs thickness was a bit too low on the first batch but that's it. It will be fixed in the next batch. Other than that they work flawlessly. I can grind as fine as I want. I have nothing to complain about them.
I had the ssp unimodals v1.
It's a bit early to draw any hard conclusion yet but so far as you can imagine the extractions are much more balanced. Less focused on clarity and more texture. Plenty of room for adjustments in the espresso range whereas the unimodals had a very narrow sweet spot.
Just got a P64 with the Mizen burrs installed. First time with flat burrs, so I don't have a great point of comparison, but compared to the Niche there's a night and day difference for V60s. Still a nice body, but the clarity is amped way up. First comparison that came to mind is a layer cake (Mizen) vs a cake pop (Niche) (don't ask why...).
Thanks, this is music to my earsBunkmil wrote:I had the ssp unimodals v1.
Have they given an update on the stock situation? Have the opened up orders to us lowly dregs with DF64s?
Oh, and to keep the levers going, I've got a Pro800
LMWDP #726
Wayyyyyy finer than the quick start guide said to. I'm at 3.3 with a light roast Costa Rica.YoshiKenji wrote:What grind setting are folks with the Mizen's using for v60?
Wow that's way lower than I was experimenting at, good to know! Might explain why I've been getting dull flavors. Your chirp point is at 0 on the dial? Also, what v60 technique/recipe do you follow?
So, I'm assuming that it's at 0 like Option-O says, but my grinder adjustment dial won't move past 0, so they never actually chirp. If I remember correctly, that's one of the recent changes-unless you change the 0 point, they've done it for you so you don't risk damaging your burrs. But I'm a little skeptical that the 0 on my dial is the chirp point of the burrs just because I'm having to grind much finer than they recommend. I'm not using this grinder for espresso though, so not too worried about it not going fine enough.
For recipe, I usually do Hoffmann's, but I've been experimenting with a new one I saw on Reddit. 15g grounds, 50g bloom for 1 minute stirring with a spoon once or twice, then slow circles close to the grounds until you reach 230g. Swirl a little when you're done pouring. It's working well for drawing out the bright tropical fruits of this anaerobic natural I'm drinking.
