One Niche Zero; Decaf coffee at night. Drinking caffeine?
I know the Niche Zero isn't actually zero retention - easy to get a little left over. I also know from cleaning it out!
Question is, for single dosing caffeine during the day and decaf at night - how much caffeine might I get into my decaf if I do it on the same grinder? Insignificant, or possibly enough to cause inability to sleep if I am sensitive to caffeine?
- baldheadracing
I'd guess insignificant.
- cafeIKE
- Supporter ❤
Do you live alone?
Buy a quiet grinder one can converse over and blast people out of the room with a shop vac?
Ian's Coffee Stuff
- drgary
- cafeIKE
- Supporter ❤
Gary,
I'd like to see the ejecta from a blow job
Is it done pre grind to remove dried stales, post grind into the cup or discarded.
I'm serious as I have a Niche.
Ian's Coffee Stuff
I think most people agree that there's less than .5g of exchange happening in the Niche between doses (DaveC said <.3g in his review years ago). So for an 18g dose, that's less than 3% of your coffee coming from the last dose.
"Decaf" still has about 3% of the original caffeine of the beans, depending on the process used. So the caffeine coming from the retained grounds is about equal to the caffeine you'd have anyways in the decaf shot, leaving you with espresso that has maybe 6% the caffeine of a shot of regular espresso.
LMWDP #718
- drgary
cafeIKE wrote:Gary,
FWIW it's not much, but I blow out the grinds after every shot, so it doesn't accumulate.
LMWDP#308
LMWDP#308
