Niche Zero grinder - Page 61
I just joined the party! Delivery due sometime in March
- ash4889
HiJavier wrote:Well, I just ordered one in black.
Looking forward to it. Will feel strange at first, after so many years of only using a hand grinder (OE Lido 2).
I wanted to know why did you go with the black color, did the same thing but now I'm confused with my choice?
Received my White Grinder today. Had a few marks on the body that cleaned up with soft scrub cleaner. First 10g dose produced 9.75g in the cup. Subsequent doses showed a loss of .1-.2g so retention is not a problem. Playing with the long preinfusion so need to grind near zero, shots taste good. Have a K10 WBC and the NZ seems as good if not better tasting.
Wife loves the looks and the fact that it's smaller than the K10 on the counter. Workflow is so much easier than sweeping out the K10 doser. Very satisfied with the purchase.
- jchung
I just wanted to post an update on my PF Stand. I added an alignment tab to keep the PF Stand from wandering while grinding. Also added a notch in the back to support a PF Funnel with a front and back tab. I tightened up the PF Funnel as well so that it is tight enough to stay put and but still remove reasonably easily.
I'll update Thingiverse for both the PF Stand and Funnels later today.
Here is a video of the PF stand in use...
And some photos
And some photos
No particular reason. Both colors look good.ash4889 wrote:Hi
LMWDP #115
Joo, that looks great. Thank you for sharing.jchung wrote:I just wanted to post an update on my PF Stand. I added an alignment tab to keep the PF Stand from wandering while grinding. Also added a notch in the back to support a PF Funnel with a front and back tab. I tightened up the PF Funnel as well so that it is tight enough to stay put and but still remove reasonably easily.
LMWDP #115
Wow, so glad to read this.Bill33525 wrote: Have a K10 WBC and the NZ seems as good if not better tasting.
LMWDP #115
