Niche Zero grinder - Page 236
no i think u pay first and then they ship 3 months later
LMWDP #663
For that price range you will not find any grinder that can compete with Niche (hardly with double/triple the price). Unless you go the hand grinder route. Pharos is one very good economically solid performer, but you'd have to be the motor.silkypull wrote:i'm on the fence for a NZ to pair with my first spring lever. no doubt the NZ has picked up a lot of momentum in sales and next delivery is in Sept. with shipping and US currency exchange, it's not at $680 range. for that price range would you recommend going with some other grinder or would NZ be the one all end all?
- prof_stack
I have a Pharos that has been retired since the Niche Zero arrived. The Pharos indeed is terrific, with 68mm burrs. I tired of daily ritual of clamping it to the counter and after grinding shaking/tapping it to get all the grinds out before putting it away until the next time.Nick Name wrote:For that price range you will not find any grinder that can compete with Niche (hardly with double/triple the price). Unless you go the hand grinder route. Pharos is one very good economically solid performer, but you'd have to be the motor.
LMWDP #010
With the NZ, every time when you make an adjustment, do you have to grind through a couple time before the burrs needs the exact setting you dialed it into?
For my built in grinder on BE870, I noticed it usually goes through two or three grinds before it start to reflect the adjustment I made.
LMWDP #663
No. That's sort of the wonderful thing about this grinder. It barely retains coffee (think ~0.2g) so your grind adjustment will be reflected immediately. Much less wasteful!
Brian Hong
You are describing retention - Niche is extremely low retention.silkypull wrote:With the NZ, every time when you make an adjustment, do you have to grind through a couple time before the burrs needs the exact setting you dialed it into?
Try this scenario I've found:
new bag
grind
pull a shot (say, off the charts, 18g/70g out, want to get to 18g/36g)
adjust it
grind
pull (magically nailed it, I get 18g/36g)
pull another and find I've dipped a little lower (18g/25g)
pull again and its consistent (18g/25g)
But, if you do this:
new bag
adjust it
grind 5-6 beans, throw this out
grind
here on is stable
But its very low retention, it doesn't take many beans to "flush" to be stable.
Thanks guys... y'all just pushed me over the edge and bought the NZ white for Sept delivery. That'll give me close to 3 month to save up and decide which spring lever to pull the trigger on.
LMWDP #663
Check out the Cafelat Robot. I'm seriously considering selling me Gaggia classic to get the robot.
Significant upgrade in the quality of espresso when moving up to the Robot.
Can't wait to get my Niche in July! Echoing the people above - I have a Cafelat Robot and love it. Currently paired with my Helor 101 but can't wait to get the NZ and give my arms a break!
Brian Hong
