Niche Zero flat burr set conversion from sworksdesigns - Page 3
Giampiero
#21: Post by Giampiero »
I think flat burr paired with the low motor/gear RPM, will not drastically increase mechanical stress, anyway the Niche bearing are well visible in one of a Niche tear down video on youtube.
Adding a thought, maybe the low RPM will eventually take part in an increased retention, and or in another effect related with the different burrs feeding speed.
gravy
#22: Post by gravy »
I have a Niche and flat burr envy and I'm interested in this. I blame Lance Hedrick. I drink almost exclusively espresso only through, so perhaps my envy is misplaced. That said I didn't like the results of my pour over experiments and if I am to believe Lance, the Niche may be to blame for that. Seems more likely I'm just not a fan of this coffee style though.
Jonk
#23: Post by Jonk »
Especially the 54mm "ditting" steel burrs and 58mm SSP brew burrs should make a big difference for pour over. You can try and slow feed your stock Niche with a few beans at a time to get an idea of what kind of grind those burrs produce and if you like it more. It'll be somewhat in the same direction anyway.
JamesB517
Supporter
#24: Post by JamesB517 »
That is fascinating! Thank you for sharing.
thirdcrackfourthwave
#25: Post by thirdcrackfourthwave »
gravy wrote:I have a Niche and flat burr envy and I'm interested in this. I blame Lance Hedrick. I drink almost exclusively espresso only through, so perhaps my envy is misplaced. That said I didn't like the results of my pour over experiments and if I am to believe Lance, the Niche may be to blame for that. Seems more likely I'm just not a fan of this coffee style though.
Lance is spot on with his observations about Niche and pour overs.
