Niche Zero dosing cup - Page 2
"Anti-static" feature really works. Only day 2 using the NZ. Decided to dose directly into the basket using an aluminum dosing funnel. The funnel covered in coffee tenaciously clinging to it. Using the dosing cup and DaveC's chopstick method. Virtually no cling in the cup. A tap cleared the cup.
Bit weird. Same coffee. Using the Macap M7 there was significantly less static issue. M7 is I think 83mm conical with ~400 rpm motor. Maybe the M7's doser reduced static with each whack?
LMWDP #151
