New version Ultra grinder
Sloom74
#1: Post by Sloom74 »
Hello guys, I ordered the ultra grinder from China from Mr. Zhang, and here are some pictures. There have been some changes to the design
Sloom74 (original poster)
#2: Post by Sloom74 (original poster) »
There are some changes: the body became one piece, the portafilter carrier was changed, and a spring was placed under the four bars to adjust the alignment of the upper carrier by tightening the lower screws.
Jeff
#3: Post by Jeff »
What is the current draw with the motor running and no beans?
#4: Post by Sloom74 (original poster) replying to Jeff »
Hi Jeff I don't know how this is measured
Pressino
#5: Post by Pressino »
Have you checked retention? It looks as if the burr chamber has a bit of room to accumulate grinds.
Mbonus
#6: Post by Mbonus »
Sloom74 wrote: Hi Jeff I don't know how this is measured
I'm not Jeff - but you could probably use a killawatt electic usage meter.
https://www.amazon.com/P3-P4400-Electri ... 9MDBU?th=1
#7: Post by Sloom74 (original poster) »
Pressino wrote:Have you checked retention? It looks as if the burr chamber has a bit of room to accumulate grinds.
It's 0.1 retention is negligible
#8: Post by Sloom74 (original poster) »
Mbonus wrote:I'm not Jeff - but you could probably use a killawatt electic usage meter.
I hope I can convey the information, because of my weak English. I think that Mr. Zhang solved the problem by installing a washer with a thickness of 0.1 above the washer to adjust the height of the lower carrier from the column by 10 microns, as I understand it.
