New Timemore Electric Grinder - Page 3
Hi JSPhang!
I am curious how it compares to your other grinders in terms of flavor profile.
Wait until you see the new oncoming Mazzer single dose low retention grinder, now in the last pre-prod testing stage.driftcafe wrote:Odd design, reminds me of a sewing machine or a stand mixer.
You might be disappointed if you're not into "sewing machine" shapes.
babola wrote:Wait until you see the new oncoming Mazzer single dose low retention grinder, now in the last pre-prod testing stage.
May be worth a new thread. Have you seen the Mazzer? Any idea when it will be available?
We will all have to wait a little, I was originally told it'll be announced end of Nov on one of the end of the year coffee shows in Asia, then was told Jan 2023 or little later.drH wrote: May be worth a new thread. Have you seen the Mazzer? Any idea when it will be available?
The feedback from early testers was mixed so likely some last minute mods or design changes.
What I can say is the one I saw and briefly tried was like a mini-ZM, miniature dimensions, vertical flat burrs, all stainless steel and aluminium construction, silver, home use-only will be its target market. Unless things change.
following this as I am considering this for a pourover grinder myself. but initially looking for one that can do both espresso and pourover, if at all possible.
Seems like 078S will be the most affordable option for really big burrs capable of espresso:
My guess is that those 78mm burrs provide more surface area than the 83mm options for a DF83. Low-ish RPM and supposedly no need for RDT - sign me up
Also, if 064 accept SSP burrs it seems like a good option for someone wanting to grind both for filter and espresso.
I just hope the clicks are small enough or that a stepless mod is easy.
I'm curious as well, but when i dug into the specs I was sus that the motor could handle espresso well. I think they have two different 64MM version for this reason. The 78MM I think could do both.
- Jean
