New Kinu M47 Phoenix grinder - Page 13
Guys, I am trying to grind for my Flair with Phoenix. It is normal that even on 2.2 I don't get enough fine coffee?
With my Robot and my Kinu M47 simplicity its 1.7madrian wrote:Guys, I am trying to grind for my Flair with Phoenix. It is normal that even on 2.2 I don't get enough fine coffee?
- radu
You can have even more variation on the same machine. If you use different coffees and different extraction methods (long preinfusion - blooming - vs no preinfusion). You don't need to worry that much on what the number is.madrian wrote:These numbers are seem to be more reasonable for me.
Interesting why for somebody is the good range 3.0-3.4, it's quality fluctuation or the coffee beans? Moreover there shouldn't b big difference between each Kinu models, because thread on the main shaft is the same.
On different machines you get even more variation. If I use 20g on a 54mm Dalla Corte basket is one thing, and 15g on a 58mm basket is another.
Also, for filter, a natural processed coffee with good solubility needs a much coarser setting than a less soluble washed.
LMWDP #616
Thanks, you are absolutely right.
Just for reference: my best setting is around 1.4.5 @16.5g.
