New Baratza grinder: the Sette Series - Page 104
Coffee Addict wrote:Then the beans are inhibiting the wobble. If your burrs have even a slight wobble, your $500 burr grinder will perform little better than a $25 blade grinder. I would return it under warranty and hope it isn't a weakness of the model in general.
That's what I felt. I will take a video and make sure I am not missing anything.
It's not, if you had read my post. If you own one, as your profile suggests, you'd know it's not an issue as well, or you would have returned YOURS.Coffee Addict wrote:Then the beans are inhibiting the wobble. If your burrs have even a slight wobble, your $500 burr grinder will perform little better than a $25 blade grinder. I would return it under warranty and hope it isn't a weakness of the model in general.
You are coming across a bit aggressive on this one imo. Wouldn't it make more sense to just ask him if he had checked his without beans?
There is a difference between a weakness and a feature: a weakness will not always be manifested. If we are seeing even one Sette with a specific problem, given the limited number in operation at this point, it *might* be a sign of things to come.
Have you seen the part of the Sette user guide that says: "After the first few pounds of coffee, the grind produced at the lowest setting may not be fine enough for espresso. To shift the grind range finer, a small washer (included) can be installed below the cone burr."Coffee Addict wrote:There is a difference between a weakness and a feature: a weakness will not always be manifested. If we are seeing even one Sette with a specific problem, given the limited number in operation at this point, it *might* be a sign of things to come. Let's hope not...
What is it that could happen during the first few pounds of coffee that would require a shim to be fitted? I would think that it's not the face of the burrs getting seasoned because that would be of the order of micrometers. More like plastic stretching (if my experience of the Vario is anything to go by), and good luck with that!
- TomC
Guys, take a deep breath. I have edited out the snark in the last posts and put this thread on cool down for a bit.
- floydo
Agree....although the short was not apparent day 1, the behavior was consistent thereafter....I am really liken' the replacement grinderdominico wrote:A solder bridge essentially creates a short; if the state of that particular transistor was an input to the the control circuit that activates the motor then being "always on" could definitely cause it to activate at unexpected times.
A solder bridge in the wrong place on any appliance could cause similar issues.
I'm going to try and purchase a Sette to use alongside my Major near the end of the year. If it's as good as I think it's going to be, I'll likely end up removing the Major and getting a second one for decaf spro or drip.
This makes me curious! Is there something about the Major you don't like? Mostly a size issue? It just seems a little crazy to me to replace an 83mm flat burr set with that of the Sette. I know it's not all about burr size ... but those 83's are something fantastic.
Have to agree here with Chris. The Major is a VERY popular grinder here in some cafes. It's sort of apples and oranges with it and a Sette. Keep your Major, as some coffees seem to do better in the flat burr, others the conical.
