Mazzer Super Jolly Propeller - Page 2
- mckolit (original poster)
I've been using a "Fan" to pump air through my Sj for two years. Every now and them i try to dial in without the fan...its not as good.
I tried three different fans and they all couldn't blow pressure through the beans even with fully sealed air route. I ended up with a small USB air pump. It pushess beans through faster and the outconme is a few less fines so I have to grind overall finer tyo compensate.
I have fully customised my SJ for single dosing and first experimented by blowing jently into the throat (no one else was drinking my espresso lol).
I also have the similar device thet you printed to stop all the retention in the centre of the lower burr. I was even worse with ssp burrs. I had mine turned by an engineer I found on fiver.
The italians can sure make equipment that lasts but the finer points of design certainly elude them
