Mahlkonig EK43: Standard vs. SSP burrs for brewing - Page 2
Exactly the same. I'm also using 10# for V60 and Tetsu Kasuya's 2016 WBrC method, but my burrs just ground about 1 pound and the physical zero is going finer. Now the burrs do not rub at dial 0#.Rytopa wrote:Mind sharing your pour over grind setting? I am also using a EK43S, currently at Dial 10# for V60 pour over
Thanks for the info, would using the DIY sanding method as shown below help fix the burr carrier?Terranova wrote:The EK43 S has a CNC machined housing, they are mostly accurate by <0,03mm but the burr carrier varies by around 0,1mm and if you believe it or not, this has a much bigger impact on boulders and fines than burr geometry between turkish, coffee, 2nd generation coffee burrs, SSP or Gorilla.
Every local machine shop with a lathe can fix this.
http://www.youtube.com/watch?v=8y1QwgxGLpc
- Terranova
- Supporter ❤
No, that doesn't work for the moving burr.Rytopa wrote:Thanks for the info, would using the DIY sanding method as shown below help fix the burr carrier?
Where have you gotten that info from?ryuemura wrote:Silver Knight is for brewed coffee, while the Red Speed is for espresso. I've been considering the SSP burrs for my EK43, but so far my brews have been tasting really good and hitting solid numbers (1.35 TDS, 19% - 20.7% EY). No reason to switch the burrs yet.
Hansung from SSP.
I asked about their different coatings and which would best suit my needs.
"98 mm burr set for EK43 - (silver knight coating is standard)
both are basically coated. we are using silver coating for brewing or bulk grinding, Red speed coating for espresso usage by technical spec (coefficient of friction, Hardness)"
Hi Frank, can you give the figures from the standard EK43 from say 2-4 years ago? Do you know any machine shops you recommend in Australia? Thanks you are a great service to the community, I have one of your EK alignment kits. Do you think shims can cause warping of the burr over time?Terranova wrote:The EK43 S has a CNC machined housing, they are mostly accurate by <0,03mm but the burr carrier varies by around 0,1mm and if you believe it or not, this has a much bigger impact on boulders and fines than burr geometry between turkish, coffee, 2nd generation coffee burrs, SSP or Gorilla.
So basically the difference is the hardness and friction capability of the coating. I guess the reason SSP/Hansung said what he said is that bulk grinding has a higher throughput those need a coating that gives a longer burr life and with a low as possible friction, therefore using a DLC costing like Silver Knight. While espresso this isn't as vital as the throughput is substantial lower both in overall as well as at a time grinding.ryuemura wrote:Hansung from SSP.
For a home user however, Silver Knight seems like a bit of an overkill, especially when you know that stock EK burrs easily last a lifetime with a normal home usage, with a DLC coating it would last for a few generations!
Even if I consumed 1kg of coffee beans a day, the stock burrs would almost last two decades
- Supporter ★
I've used Red Speed and Silver Knight 98mm SSP burrs on Monolith Flat MAX. No difference really in the cup really. I think grind chamber purges clean a little faster with the Silver Knight burrs.
EK43 must be modified to obtain the benefit of high precision burrs, as described above.
Interesting, where have you got this data? Will the stock burrs still be really sharp if I only grind 50-100g coffee per day for 10 years? I have an EK43 with stock burrs at home and this is the amount I grind (I only do filter coffee, so light roasts). Aligned well using Titus alignment tool.malling wrote:Even if I consumed 1kg of coffee beans a day, the stock burrs would almost last two decades
Can anyone say that their pour over / filter brews are heaps better with the SSP over the stock burrs?
Emailed Hansung recently, he said they are developing a new burr aimed at brew / pour over / filter, which has a bimodal distribution for "complexity"...he says that some people want this. I most certainly don't, I prefer the unimodal (plus fines, which I would prefer not be there!) distribution for filter coffee.mivanitsky wrote:I've used Red Speed and Silver Knight 98mm SSP burrs on Monolith Flat MAX. No difference really in the cup really. I think grind chamber purges clean a little faster with the Silver Knight burrs.
