Mahlkonig EK43 limited smaller edition - Page 3
The EK43 is 9" large at the base and this is not a problem for me but at 17+" of height i have unfortunatly a cabinet that reduce my space to only about 7" large! It is very difficult for me to find a great grinder that will do better then my actual Forte AP and that will fit this tiny space. So that is why my question. I don't know if at 18" this is the motor or hopper but i need to know the largest point of this grinder above 17" if you can provide me the info. Thanksjeebsy wrote:The width of the tower?
- Terranova
According to Mr. Martin Reichart (shop owner) there are 4 EK's of the limited edition available.Flipper wrote:I doubt that you will be able to get one of these on regular ways...222 worldwide is a really small number. We experience a very huge demand on it
There should be another MK grinder coming out in October (not talking about the MK Peak though) which is similar in the output to the EK43 with a PF holder and some kind of a volumetric dosing system which seems to be the only way to handle a busy work flow.
- CrabRangoon
If you refer to the photo you included, wasn't it just one of those limited EK43's with the Five Elephants Volumetric Dosing attachment?Terranova wrote:According to Mr. Martin Reichart (shop owner) there are 4 EK's of the limited edition available.
LMWDP #505
- FotonDrv
Beautiful chop job!
What was inside the original tower?
There's not much in there - a small plate with the capacitors and terminal block on there, the thermal overload switch and the on/off switch. It's a slightly tight squeeze in the new base. if you cut the wiring down it would be OK but I want to keep this kinda reversible so loathe to do that.
It's a wet spray - couldn't get it powder coated as the motor doesn't come out (easily). It's Audi Daytona Grey with a matt lacquer
- FotonDrv
Thank you for the info.
Do the grounds come out with such force as to spray grounds all over the counter top?
Where did you source the spare tower to chop?
That is the cutest grinder I have ever seenjeebsy wrote:Here's my DIY small edition:
<image>
It's the base from a Santos no 1 grinder. You can email Santos through their website and they'll tell you who your local distributor is. I grind into a cocktail shaker, it's a pretty clean process.FotonDrv wrote:Thank you for the info.
