Here you go. The first pictures are dirty because that's how much retention is in the grinder. But I just remembered that I did try to suck out some of the grinds from the top with my hand-held vacuum so take that into consideration. The reason why I took it apart is that I noticed there was some coffee build up on the sweepers. I'm thinking it's because of the microfines accumulating and WDT contributes to that clumping.
I take off the chute between every shot to brush out the remaining coffee grinds after giving it a few taps. Sometimes it stops right in a middle of a sweeper and you can see the buildup. As a result, when you are brushing you can certainly dislodge that old coffee buildup into your PF and can negatively affect your shot. I was careful not to brush it or touch it when this happened.
This is something that pretty much happens to all grinders though, not just particular to the Ultra. My MonoFlat did the same thing but the opening in the Ultra is much wider so it's easier in a way.
On my Flat, you can set the RPM's super low and wait for the sweeper to show and you can scrape with a pick and vacuum. On the Ultra it will not spin slower than 100rpm so therefore you can only get "lucky" for one of the three sweepers to stop for you to clean them. It's easier to take off the top of the grinder as I did. It's not scary at all. Posts are tight and you either have to get the perfect angle or gently tap it in. Mine just slipped in perfectly after some fiddling. Alignment is the exact same as long as you put it back together the same. If each notch is 0.5 microns than I have aligment within 20 microns which is amazing.
On the grinding experience itself, I really like it now that I had some time to get to "know my grinder". It all comes out nice and fluffy and I love how fast it grinds compared to the 75mm Monolith Flat which was like 30-45 seconds depending on the RPM speed. I pull back on the magnetic chute and let it snap back tapping itself against the grinder, dislodging the grinds there and then I stop the grinder, take off the chute and brush out the rest of the little bits left in the corners and such. Very quiet grinder. Satisfying grinding noise.
