Lagom P64 Flat (Option-O) - Page 74
What espresso machine is that?Peter_SVK wrote:I looks I have missed many pages of posts since my last visit here, getting no annotations .
Simple dust cover.
Right, Dalla Corte Studio FP (some minor and major mods).
- Supporter
Can anyone tell me if there is value in owning a P64 and a Monolith MAX? or is this too redundant of a set up?
I guess that depends if you need, or want, two grinders!
I'd quite like dedicated grinders for brew and espresso.
As with most things in this hobby, that's an opinion that a potential owner would have to determine for themselves. I'd consider it, but probably wouldn't plan to keep both indefinitely. Two years ago I wouldn't have even considered one of the two grinders, much less both.Cool Beans wrote:Can anyone tell me if there is value in owning a P64 and a Monolith MAX? or is this too redundant of a set up?
- autoexec
Apologies if this had been asked or discussed before: Had anybody bothered to do a pen/marker test to the burrs to check their unit's alignment? If so, how'd it go?
I got my Lagom P64 with SSP unimodal burrs yesterday. The "wave" edge of the burr is too flat to be recognized by the naked eye. I've read that you have to use near zero for espresso, but my first shot of the light roast geisha using 10 scales from zero and the flow rate is still too slow. It takes 59 seconds to have 1:2 brew ratio of 34g espresso. The coffee ground looks coaser than my Mahlkonig Guatemela did at the finest setting with much faster flow rate, and also coaser than my 804 Lab Sweet did with the same flow rate. This is the side view of the burr. Is your SSP unimodal burr like mine? Is it possible that SSP changed the burr design for espresso? Or is it just because of the alignment?
The SSP burrs quality is not as good as my thought.
Lagom/SSP unimodal burrs have no flats around outer perimeter like espresso (high-uniformity) burrs, so marker test is not possible to do. Personally I do not care about alignment while my usual setting is quite far from zero (generally at ca. 1.2 - 1.3).autoexec wrote:Apologies if this had been asked or discussed before: Had anybody bothered to do a pen/marker test to the burrs to check their unit's alignment? If so, how'd it go?
- autoexec
This is helpful as I also plan to get the SSP Unimodal. Thank you!
