Lagom P64 Flat (Option-O) - Page 220
Hi,
I own a P64 of the very initial batch.
I have issues changing the burrs. I had situation where either the top or bottom burr was so fixed, that I simply could not change it.
Is there a bullet proof approach in getting them released without messing with crazy tools or something? I would love to switch my burrs more often but I am so fed up that I don't.
I read through the last 100 pages, but couldn't find a solution. Is it just me?
Any advise is appreciated. Enjoy Xmas!
Is it the burr that is stuck, or the screws?
The bottom burr can be a bit finicky to get out, I use chopsticks to lift the burr up. Never had any problems with the top burr.
It's the top burr that is completely fixed. I unscrewed it, but I can not move it a single bit
Managed to finally unlock it with a hammer and a plastic stick.
The LCU came with a pair of these circular magnets with a screwed on loop on top to take off the blind burrs. Maybe people with burrs stuck can use something like that. I'm guessing they're strong neodymium magnets.
SSP HU P64 arrived today from Prima.
Fantastic packaging from Option-O with corner bumpers and plenty of foam. Machine is certainly built with quality in mind and weighs the part.
A few obvious things I found out quickly
1. The top burr locating pins (3 of them) can fall out if you turn the machine upside down during cleaning.
2. The Burr carrier with adjustment limit block can be installed 180* around which throws off the dial.
The new burr removal system with two socket head cap screws to loosen is painless and seems like a fair trade as opposed to having to turn out a bunch of threads. The hex key needed is included. Also, I do wish the US plug would be oriented or designed such that the machine can sit closer to the wall.
Great machine so far and will be using it for aeropress, pour over and French press with lighter roasts but do have plans to compare against the niche and test the whole flats vs cones debate for myself.
You could always replace the cord with a right-angle IEC cord:jvanderhof wrote: Also, I do wish the US plug would be oriented or designed such that the machine can sit closer to the wall.
I went through few kilograms of coffee and decided that is about time to do some cleanup and check the burrs. On the inside it was cleaner than I expected, build up was around the top burr, nothing too extraordinary.
What get me a little worried was the alignment, top burr was great, but bottom was really questionable.
I've tested all three positions and the rub was on the same place relative to the carrier, guess that it's the burr carrier. I've added foil shims below the outer edge and it's close to full rub. I had higher expectations on the factory alignment.
Is foil shimming reliable for those of you who had to do it, and how frequently do you retest it?
