La Marzocco Swift Mini with Etzinger grind mechanism - Page 5
Interesting concept indeed! Any idea on the ballpark RRP for the LM Swift Mini?
Looking forward to the review
hi, any updates on swift mini?
how is the consistency of extractions with a naked portafilter?
curious if this grinder is living up to its promise?
thank you
thank you
- HB
- Admin
Whoops. Sorry for the delay in responding mb01400! I've added closing comments in the La Marzocco Swift Mini Review. Dave (cannonfodder) has taken over and will be posting his thoughts next.
I do have one question about the final results. On the days when the Monolith won by a significant amount was the Flat better or the Swift worse?
Ira
Ira
- HB
- Admin
The Monolith was better; I'll clarify that in the writeup.
Or maybe that was the wrong question. If the Swift was so consistent, why was the Monolith so much better on two days or why was the Monolith so inconsistent? What about a test comparing two Monolith Flats over a month using the same protocol? Seems like that result raises more questions than it answered.
Ira
Ira
- HB
- Admin
I don't want to over-emphasize the difference; all espressos from both grinders fit in the good to very good range. If we really want to trace it to a cause, the difference appearing later in the week would be a good one to pin it on (i.e., as the coffee aged, the difference that the Monolith could exploit faded). But that's speculation on my part.
Of course, there's another possibility: I'm an average to below-average taster. That would not hurt my ego, since this site is called HOME-BARISTA.COM for a reason. But even that I doubt in this case, since it doesn't take much taste ability to tell the difference between good and very good in XYZ -- if they're served side-by-side. For the longer version of this same point, see Peter Giuliano's comment in SCAA Sensory Skills [Psych] Test.
It appears the height of this grinder is 18-1/2 inches, which is too tall to fit under standard cabinets. This seems to be a major miss on the part of la Marzocco. If this is being targeted towards home users, why wouldn't they have found a way to make it an inch shorter?
Based on my calls to a couple of distributors, factories resumed production in April/May and the hope is that they'll be on sale in the US by late summer (July/August).ConFlatExp wrote:so when will this be available in US?
