Krups GVS2
BIKERBOB
#1: Post by BIKERBOB »
Good Day
Is it possible to adjust the burrs in the above grinder; currently at the finest grind it is still to coarse for espresso
Thank you
Bikerbob
mwebber
#2: Post by mwebber »
The Krups GVS2 appears to be an ice cream maker. Are you sure that's the model number for your grinder?
Jonk
#3: Post by Jonk »
I'm assuming it's the GVX2. You could make shims and put under the burrs, there are reports that this will work.. Or just buy a proper grinder, most if not all of the Krups lineup is rubbish. They do sell a re-badged Graef that's OK.
Edit: I now see you've got a Vario - why not use that instead?
