Kinu M47 Simplicity
When I emailed them last month they had said:
I'm not 100% sure how the upgrade will work since their burrs are machine fitted for perfect alignment.We are already study more than 1 year a specialized brew burr set. Once you have purchase a Kinu model using an 47mm, you can simply upgrade to a brew burr set in the future once we will have finish the development and offer it in the webpage.
In theory, you will be able to replace only the mobile burr. Remains to be seen how much will it change the grind distribution.
- radu
In practice, you only change the inner burr and you use the new burr. Works only for filter.
If you need any more info, I am at HOST, so I can ask them.
LMWDP #616
- autoexec
Have you confirmed this to be the case? If not please do. And how much will they be selling the burr(s). Thanks!
Wow interesting... hopefully international distributor (Indonesia/Jakarta) will import the optional brew burr, when the optional filter burr will be launch officially?radu wrote:In practice, you only change the inner burr and you use the new burr. Works only for filter.
Cheers
I am curious about the differences between the Phoenix and the Simplicity. Does anybody know where the additional $75 come from on top of the Phoenix?
- guijan12
Is that so?namelessone wrote: I'm not 100% sure how the upgrade will work since their burrs are machine fitted for perfect alignment.
I still received the burr removal tool with my Kinu M47 (2018 model).
Why would they have done that?
Or is this only the case for the later models?
Regards,
Guido
Guido
The Simplicity is a full on metal M47 without the metal grounds cup and with some plastic around the top. The Phoenix has plastic parts inside.fiechtl5 wrote:I am curious about the differences between the Phoenix and the Simplicity. Does anybody know where the additional $75 come from on top of the Phoenix?
- radu
As devlin said, the Simplicity is an M47, not a Phoenix.fiechtl5 wrote:I am curious about the differences between the Phoenix and the Simplicity. Does anybody know where the additional $75 come from on top of the Phoenix?
It is the identical body of the M47 (the expensive one), but with a plastic funnel and a plastic cup. The magnetic cup can / will be available to buy separately and it can be used on the Simplicity.
@yan - the brew burr will be available in two months.
Update: this is the brew burr. It will be coated black, just like the rest of the Kinu burrs (the left is the brew burr, right is the standard burr).
LMWDP #616
