Kafatek Monolith Conical - August 2017 version - Owners Thread - Page 7
Denis said in his email 5-8lb atleast for the conical. I personally had a ton of coffee left over from my Counter Culture subscription before I started vacuum sealing and freezing my beans. So I ended up running a little under 15lb in total the day I got the grinderCapitol wrote:Just curious... How many lbs are folks grinding through to season the burrs? Is there an official recommendation for the conical or flat from Kafatek on this?
Denis also recommended running a pound at a time and leaving 10-20 minute breaks in between just to reduce stress on the motor. He said although he knows people that just run it all through (the machine will turn off when it gets too hot), he personally doesn't feel the the need to put the extra stress on the motor. I went with 20 minute intervals to be safe.
Barb replied. They are out of stock but only for a few days. Placed the order and they will send it as soon as those come in. She mentioned that is was just a few days away.TomC wrote:You want one of these. They're a perfect marriage for the MonoCon.
http://www.orphanespresso.com/OE-Stainl ... _5719.html
Note, this link takes you to the 53mm version. I have it in 58mm and I prefer the polished stainless steel. They do have thin ones in aluminum in various sizes. But you might have to ask them or look around for the stainless in 58.
http://www.oehandgrinders.com/OE-Stainl ... _p_58.html
I have a smaller version that I use with the Breville... using that for now.
Searching for that perfect espresso!
Wachuko - LMWDP #654
Did the supplied funnel not work for you? The current funnel supplied by Denis is flared at the top, and the new chute is longer so pretty much all the ground lands in the basket. I find it works pretty well.
Same here I upgraded everything on my grinder week ago and new chute + new funnel is perfect combo.
Same here. It shoots out like a perfect dark stream of coffee.
Maybe if I move it closer to the chute... but as it stands right now... grounds everywhere One time it was because I had installed the chute incorrectly... but still grounds everywhere when installed correctly...
Using this for now... no grounds outside the PF.
I guess I'm confused as to why you aren't RDT'ing. Seems like a simple solution.wachuko wrote:Maybe if I move it closer to the chute... but as it stands right now... grounds everywhere One time it was because I had installed the chute incorrectly... but still grounds everywhere when installed correctly...
<image>
I see, you need to move the fork up, by a lot! Loosen the 2 middle screws and use your portafilter+Monolith funnel to estimate the height. I adjust it so that the chute is about 2-3 mm (vertically) away from the funnel.
- TomC
Yeah, you definitely need to move your fork higher. You may not even need the OE part. All you need is for the Monolith dosing ring to clear the very bottom of the snout of the output chute and you should be good to go.
Denis' new funnel looks nice. I considered emailing him and asking about a retrofit (updated) snout, but I don't think I need it since I am already using the OE ring. But I suppose if I didn't have the OE ring, I'd want his newer spout and newer dosing funnel.
