KafaTek Monolith Concial: Production Run #10 User Experience - Page 9
Man, if only people didn't spend their days analyzing grind particles of their $3,000 grinders, I think we would have found the cure for cancer by now
That might certainly be true, but since I'm no bio-physicist I might as well try to maximize everyone's enjoyment of caffeine!
Just camping on to what a few people have uncovered about using something a little more sophisticated than a palm pump to remove the last little bit of coffee grinds from this grinder. This hiking cup really, really does the trick and it sits well on the top of the grinder with or without the safety funnel. Not sure how it will sit on the gen3 angled models, but it should still work, IMO. Use it upside down and puff all the air you need to clear the grinder 100%. Get the 250ml size, and I chose gray for the color. $10 through Amazon. Here are some pics.
I assume you have to remove it to "reset" and expand the cup everytime?BaristaBob wrote:Just camping on to what a few people have uncovered about using something a little more sophisticated than a palm pump to remove the last little bit of coffee grinds from this grinder. This hiking cup really, really does the trick and it sits well on the top of the grinder with or without the safety funnel. Not sure how it will sit on the gen3 angled models, but it should still work, IMO. Use it upside down and puff all the air you need to clear the grinder 100%. Get the 250ml size, and I chose gray for the color. $10 through Amazon. Here are some pics.
<image><image><image>
no, i think he is using it in its compressed form to move air.
Hi Sean,YseanY wrote:I assume you have to remove it to "reset" and expand the cup everytime?
No...that's the neat thing...using it upside down just flexes the silicon disk to make it act like a puffer not a cup. It never expands when pushed from the opposite side. Just like chris_n said.
Maybe a video would show it better?
- Randy G.
Video, yes, please...
Thanks! Video would be great. Also, if you could see if it would fit the grinder without the safety funnel would be appreciated. I don't have the safety funnel so not sure if there's a size that would fit.BaristaBob wrote:Hi Sean,
The same size works with and without the safety funnel.
For around $10 you can't go wrong, imo.
For me, words cannot describe how perfect this thing is for puffing grounds.
https://www.amazon.com/Giottos-AA1900-R ... way&sr=8-3
(I removed the red part btw) it fits perfect in the little bean hole and is stronk.
