HG-1 Prime user experience - Page 8
- EvanOz85
Anyone have recommendations for getting beans into the funnel? The space between the funnel and the top of the grinder is extremely small; too small to tip my dosing cup into.
Found this on amazon - its 1.8 in diameter and the shaft gap on the HG1 Prime is 2 in.
https://www.amazon.com/Stainless-Health ... 136&sr=8-3
I use this for my Pharos. Works excellently for dosing/weighing/pouring. It's flexible so it pours easily.EvanOz85 wrote:Anyone have recommendations for getting beans into the funnel? The space between the funnel and the top of the grinder is extremely small; too small to tip my dosing cup into.
https://www.oehandgrinders.com/silicone ... osing.html
- intjester
This is similar in shape to the other ones posted, and also works well. Due to limitations of my space, I have my HG-1P up against a wall on the left, and I can still get in there with this just fine.EvanOz85 wrote:
https://www.amazon.com/dp/B09DV36TPJ
- intjester
Also in regards to my small space, it has to sit on top of a wood cabinet. That was not working well for stability - I got lots of hopping. This gets worse as any coffee grinds that have fallen end up scootching between the base and counter surface and act as ball bearings. I did not want to drill it or stick it down with VHB tape for permanent mounting due to the hassle of removing it for cleaning.
I ended up purchasing a smooth granite board which is heavy enough to stay in place on the cabinet and provides way more friction with the stock silicone base of the HG-1P. I figured I could drill or tape to that if needed, but in a pleasant surprise that has been completely unnecessary. No more skipping, easy to remove and lay it down for a deeper cleaning, looks nice.
Does anyone know of a source for a nicely made metal popcorn lid that fits the funnel and shaft? That is my last little annoyance to resolve, but I cannot bear the janky plastic solution. Well that, and that I keep emptying the tumbler into the robot portafilter with no basket present on no-coffee-brain ... but that is hardly the fault of the grinder.
https://www.amazon.com/dp/B074SFGDHK
You could order the "popcorn lid" that is designed for the WW Key grinder from Weber.
- intjester
Would love to, but I don't see it for sale.
https://weberworkshops.com/collections/parts
Email them, I've purchased parts that weren't on their published list.
