Ion Beam static reducer - Page 11
pulakbhatnagar
#101: Post by pulakbhatnagar »
This arrived yesterday and had NO noticeable effect on static when grinding on either the Niche Zero or the DF64.
@luvmy40
I'm no expert, but it may be possible your grinder is generating different static charge than mine? It works very well for me.
It works for FBM as well, check
espressoren (original poster)
#102: Post by espressoren (original poster) »
They ordered a different device, though similar. Maybe it just doesn't work as well as the other.
Sproyo
#103: Post by Sproyo »
luvmy40 wrote:This arrived yesterday and had NO noticeable effect on static when grinding on either the Niche Zero or the DF64.
It could be a dud. You can try filling a cup with smoke and see if the ionizer clears it up.
This https://a.co/d/0Yketjn was the cheapest I could find. It works for my df64v as well as the before/after pics I've seen of other ionizers.
Maak
#104: Post by Maak »
Jeff wrote: Around $5 on AliExpress,
I brought a similar one on aliexpress with two dual emitters. however there is a red AND white white attached to each pair where you have two whites. Aprrantly mine does posative and negative ions but no destaticing results with grounds yet.
I suspect maybe im shooting both posative AND negqative ions at the grounds.
I'll try and separate the red cabled beams from the white cabled beams and see if that works.
Does anyone know how to test the beam to see if its producing posative of negative ions?
Maak
#105: Post by Maak »
Well I tried splitting up the red cabled emitters from the white cabled ones asuming + and - ions.
Using either the + or the - pair makes no differnce to the grind
