Grinder studies by Socratic Coffee - Page 2
This study is designed to look at similarities and differences in the grind. If the data showed distinct similarities or differences between certain grinders, (eg flats and conicals showed distinct distribution patterns, or big flats showed differences in distribution than small flats), then we might be able to extrapolate that data to the empirical taste data that is perhaps already available. It also might point a grinder or burr company to seek to modify their distribution profile to achieve certain characteristics in the cup.ds wrote:So how do you do that if you don't taste the espresso? Its impossible.
I don't think we know what distribution is yet optimal for espresso, if there is a single one. Unimodal may be less desirable than bimodal or multimodal. Is grind consistency (particle size within a given dose) more or less important than grind consistency (constancy of the distribution between doses)?
Of course, apart from taste, we don't know what it yet means. But you don't have to get all the info in a single package.
- dergitarrist (original poster)
They're finding out what grind profiles different grinders have. This has nothing to do with taste within the confines of this test.
They're just dialing in the grinders pulling shots just so the grinders are set to comparable, real world settings. Of course, this has implications for taste but that's not what this research is primarily focussed on. The question here is not "which grinder produces the best tasting shot?" but simply: "which grinder delivers what kind of distribution?"
There are going to be correlations between those two questions but their research is focussed on question #2. The theory behind what that means for question #1 should really be discussed outside of the actual research they're doing but anyway: My understanding is that a grind that is all over the place is going to result in under- and overextraction at the same time with a fair amount of proper extraction in there. How large that share of proper grounds is (the large hump in the graph) determines how good a grinder is according to this hypothesis.
Put simply, say, the optimal extraction for your coffee A would happen at 18g of 200µm particles. That's the shot you like, that's how that coffee is supposed to taste, that's the godshot, the maximum potential of that bean. But: You could get the same extraction time and shot weight if you use, say, 14g of 130µm particles or 22g of 270µm particles but the best extraction happens with 18g of 200µm particles.
Now, of course no grinder is going to produce a perfect 18g of 200µm particles. That's NASA stuff right there. An almost perfect result would look similar to that Ditting curve with, say 80% of the grounds within the 170-230µm range. Great. If you have a Mazzer Mini, however, you're only going to get 40-50% in that range and then, say, 30-40% around 350-450µm and another 20% or so all over the place. That shot is still going to be good, because 40-50% of the coffee are properly extracted. The rest, however, will either be over- or underextracted and you'll probably taste that. It's always a mix between *both*, over- and underextraction. If overextraction dominates, you might grind more coarsely but that'll also move the 40-50% of "proper" grounds away from the optimal range, so you'll go back and you're never able to absolutely nail it. You'll never know the full potential of that bean, *if* uniform grind size distribution is indeed optimal - we don't know that yet! Some people might argue you need fines to seal a puck properly...
An early hypothesis, looking at their data, would be that burr grinders have two humps:
While konical grinders have one larger hump and then a fair mess of larger particles:
It seems that the Robur has a larger portion of "proper" grounds and then some larger particles that are going to be underextracted. It could be that that cup tastes better because there's more "proper" extraction happening and the larger grounds don't matter as much and just result in a thinner cup. It could also be that the optimal setting for the Major is between those humps as it appears to become smaller with seasoned burrs... Now, this is where taste testing would come in. But it'd be educated taste testing at this point, not just "I prefer this grinder, I don't know why, who cares?"
So, tl;dr: Kudos to them. If we try the same coffee from different grinders in the future and clearly prefer one, this data might put us in a position to make an educated guess as to why.
LMWDP #324
plus oneBluecold wrote:They have not shown any real reason why the seiving tests are suitable for coffee grinder analysis. They have just given a few reasons why laser diffractometers aren't really suitbale, but also raised a few points against seiving. They did not show that there is a measurable difference between two samples, that can correlate to taste.
A possible way to do this would be to replicate an ek43 shot by taking portions of seived robur grounds. Until they do that, or something similar, then they're just producing noise, and everybody who is drawing conclusions based on that graph is being suckered by pretty pictures.
- baldheadracing
Given previous history of Instagram pics from Socratic, I prefer to wait for the full report to be posted on their website.
- Bluecold
Until they can show that sieving accurately defines the grind profile of the grinder (they haven't), they're just producing graphs based on a test protocol.dergitarrist wrote:They're finding out what grind profiles different grinders have. This has nothing to do with taste within the confines of this test.
I can make a lot of graphs as well. I could find out the angle of repose of a set of ground coffee. I could find out how much friction two glass plates have for a given dose of coffee between them, I could use an air blast to find out how far I can blow a given dose of coffee and what the spread is.
Point is, making graphs and pictures isn't hard. It's also not hard to come up with potential explanations for a given behaviour.
But unless you know the boundaries of your method, you're not producing useful data.
No they are not, the only thing they're answering is what happens when you sieve grinds in their machine and weigh the result. How this pertains to distribution is barely defined, let alone taste (on which you go on a huge tangent for the rest of your comment).
It will only allow internet forum armchair analysts to make smart sounding guesses.
There is already enough bogus data floating around the web. Nobody in the public domain knows what makes a grinder good or what makes ground coffee good. Distribution is just one part of the coffee, and until anyone knows how to accurately measure ground coffee distribution, we not only don't know, we don't even know what we don't know.
If ground coffee can be measured for distribution, we can investigate how distribution influences taste, or even if it is a main taste driver. But we're not there yet. If we act like we are, nobody is advancing the state of the art anytime soon.
If Socratic coffee does post convincing evidence that their testing protocol has merit, then I'm of course very interested in the data.
LMWDP #232
fair enough... of course there's more to grind quality than just particle distribution (for instance: shape, surface area, does coffee get cut, broken or literally ground down and what does that mean when it comes into contact with water?), and of course the test method needs validation. All very valid points.
Nevertheless, I just appreciate the fact that they're not simply giving up on understanding what makes a good grinder like large parts of the industry (grinder manufacturers as well as roasters and cafés) appear to have for the past four or five decades. Granted, there are exciting new grinders and hypotheses out there, these days, and it's really picked up in the last 3-5 years or so but before that, it was staggering how unchanged grinders had remained for so long.
LMWDP #324
- millcityroasters
This is from the first results post. A possible explanation from delanocoffee:ds wrote:So how do you do that if you don't taste the espresso? Its impossible.
"Taste is pretty subjective. But from what we have read and heard (cue Rao, Kaminsky and Perger) is that particle distribution is really about reproducibility. Having a grinder that cuts coffee into a very tight particle spread (ditting) gives a very accurate surface area over and over again. Water when acting as a solvent only strips from the surface area of the ground coffee. Grinders that have even minor fluctuations in the fines (dust) and boulders (large chunks) change the overall surface area quite rapidly, which will change the yield and flavour of whatever coffee you use, each time you produce an espresso. Looking at that graph the Ditting is the grinder to use if you want to produce the same espresso (yield and flavour) over and over again."
I know I could argue with this if I was so inclined, but since I'm totally in love with my new (to me) Ditting 804 I'm taking it as confirmation of my purchasing wisdom.
Loving my 804 too! I bought it mainly as a brew grinder but do play around with it for espresso too.
I agree, this study is about the grinder particle distribution and taste is very subjective. Even if you dig into the method, the sieve method would not provide the same result as laser diffraction method due to limited bin size and tendency for agglomeration.
If you just look into the graph unimodality the Ditting stood out the most but that's not the whole story. A while back on periscope Tim Wendelboe explained his method of grinding the same beans in Ditting KR 804 and EK43. I think he specifically mentioned that he uses EK as his high end grinder where he can extract more TDS and the Ditting as a more "normal" grinder to make sure that his coffee tastes good for both end of spectrum.
- keno
Says who? I want a grinder that makes good tasting espresso. I couldn't care less about technical specifications like this unless they directly relate to improved taste, reliability, or functionality.dergitarrist wrote:Grinders are a very technical thing, so I don't mind the strictly technical approach towards grinder performance. They're supposed to grind as uniformly as possible and it's interesting to see that some are up to the task more than others.
Based on these "technical specifications" the Mazzer Mini is better than the HG-1? Nonsense. That just goes to show that these distributions are not directly related to taste, at least in any as yet discernible way.
