Grinder motor size and why it makes a difference
I was curious, if burr size, and rpm's were the same for two different grinders, but one had a larger motor. What is the advantage?
- nickw
Torque.
Primary benefit is when starting under load. Some grinders can stall when grinding lighter roasts.
So if you compared a 250w motor to a 500w motor the only advantage would less of a chance of stalling?
More torque and less chance of overheating and jamming.
Lock and load!
Would you consider a 250w motor underpowered for 64mm burrs?
- Randy G.
Is this just a thought exercise, or are you comparing specific grinders. Wattage computations do not always translate to real world use. The motor, regardless as to the rated power, needs to be compared to the burr design.
A bit of a thought exercise and comparison. I'm trying to learn as much as I can while researching a new grinder to purchase. I guess the two grinders in question would be the:
http://www.eureka.co.it/prodotto/zenith_65-e-2/?lang=en
And:
https://www.seattlecoffeegear.com/rocke ... to-grinder
Thank you
And:
Thank you
- canuckcoffeeguy
Looks to be related to this:Randy G. wrote:Is this just a thought exercise, or are you comparing specific grinders. Wattage computations do not always translate to real world use. The motor, regardless as to the rated power, needs to be compared to the burr design.
Rocket's new grinder, the Macinatore Fausto?
For the OP, my general understanding is that flat burrs need to spin much faster than conical burrs. Since flats need to spin fast enough to throw grinds outwards. While conicals rely on gravity for the grinds to drop down.
How this relates to a motor's power is beyond my pay grade. I'll defer to others to comment.
- BaristaBoy E61
Torque.
Greater ability to adjust to a finer grind before starting the motor without jamming once the grind is initiated.
SR
SR
- nickw
Conical burrs require less torque. It's just simple leverage as the diameter of the cutting surface is smaller.canuckcoffeeguy wrote:My general understanding is that flat burrs need to spin much faster than conical burrs. Since flats need to spin fast enough to throw grinds outwards. While conicals rely on gravity for the grinds to drop down.
For instance, comparing a Mazzer robur and major:
- The outside diameter of the robur male conical burr is 49mm, which is the final/fines cutting surface (even though they call it a 71mm burr, which is the female burr OD).
- The major is 83mm for final cutting surface.
Would be similar to increasing the tire size on your truck. It will take more to turn them.
In regards to the original post. I'm not familiar with the Rocket grinder, but it looks a lot like a rebadged Mazzer Mini.
