Grind Setting Sticker For Mazzer Super Jolly?
I find the grind setting marks on the adjustment ring to be more than a bit tedious--counting each "rib" between the 2 and 3 mark (where 99% of my espresso grinds land) is kinda a PITA. It'd be nice to have sticker/decal attached on the top of the grind adjustment ring that had numbers on it for ease of replicating the grind. Short of making my own, does anyone know if someone makes something like this?
"Chop your own wood--it will warm you twice."
LMWDP #522
LMWDP #522
A while back there was a guy from AU that sold plastic etched scales like what you're talking about. He doesn't do it anymore as far as I know. The best you can do now is this... which is pretty darned good!
Improved grind setting rings for Mazzer & Macap grinders
Orig links are dead, so go to the 4th page, first post. Unfortunately, the PSD files are not layered so you can't move layers around and such.
The mini and sj use the same adjustment wheel, so the mini template should fit your grinder.
Thanks!!
LMWDP #522
LMWDP #522
