G-IOTA / DF64 espresso grinder - Page 71
the coarest end of scale is coarser than I want with the Italmil burrs, I can't speak for other burrs but I would be surprised if it wasn't the same with any other burr. You could custom print a sticker for pretty cheap if it's important to you, or pop the whole plate out and get a custom one. I get the desire is to want it to go all the way and maybe there is purpose to it so you don't get confused and set it under 0 and damage the burrs. for those buying this scale would probably know the difference and they could have just made it red or some extra color to remind you. the warning/blank area looks like it takes 1/4 of the scale which is better than the NZ which takes probably has 1/3 of the area unused. I'm sure the NZ served as part inspiration for the design process and it might be why it's the way it is.Noboundries wrote:I approve of the update on the text and adding the ranges, but it's a pretty big mistake to not have the scale rap all the way back around. Especially for those that are swapping their burrs that was kind of a necessary fix, if your having the manufacturer print you a whole different scale, why not fix the actual problem with it?
How would this grinder compare to a used Mahlkonig k30? They seem to go for 450-500 usd where I live, so very similar pricing tier/burr size.
Not sure how they would compare in the cup since the burr geometry is not the same. The SSP HU seem like the closest match to the Ditting K30 burrs.
As for workflow, they are pretty much at the opposite side of the spectrum. The least we can say is that these two are not direct competitors...
LMWDP #592
Do you know what it looks like and if it is available for purchase?heytchap wrote: The mfg is making a new anti-popcorn "device."
And lObin, yes Cafune will have all the SSP listed as soon as his shipment arrives. Justin is keeping me updated but it is taking much much longer than he thought!
I just placed an order from alibaba directly. I am in Montreal as well I'm sure I will eventually upgrade the burrs, do you know if Cafune have a real physical store I can walk in? They don't mention any address that I can see on them web site.I'm tired of buying everything on line!
Regards
Pierre
Regards
Pierre
Salut Pierre! FĂ©licitations pour ton achat!
I believe Cafune is an E-store only. I could be wrong but it doesn't look like they have a storefront.
I'm sure you'll love your G-iota! It doesn't require much modifications to become a wonderful performer.
It's worth checking the alignment and shimming for optimal results (or just to sleep soundly!).
I strongly suggest getting a funnel for the dosing cup. I got a 53mm black aluminum funnel from Aliexpress (also available on Amazon). Perfect fit.
A 3D printed pointer and anti-popcorning funnel are easy upgrades.
Amanda offered to help "ease" the custom and duty fees. Ask her if she hasn't already. You probably already know how painful it can be to deal with UPS in QC...
Cheers!
Cheers!
LMWDP #592
do you happen to have and linked examples of these 3D printed upgrades?LObin wrote:A 3D printed pointer and anti-popcorning funnel are easy upgrades.
Here is very useful site with everything related to this grinder.
https://www.notion.so/DF64-G-iota-Repos ... 1d3959f360
You can find all 3d things in there.
Does anyone know size of the screw that holding the burr? Thanks.
Hello...
Been reading through this thread wondering if I should pull the trigger on their grinder over the Sette 270? Currently using a JX Pro hand grinder. Wondering if the Sette 270 would just be an easier grinder as I'm still fairly new to espresso and only working with an Oscar 1.
Also located in Vancouver so perhaps could get SSP burrs through Cafune
