G-IOTA / DF64 espresso grinder - Page 52
Anyone here who can compare the G-IOTA to a Eureka Mignon XL?
It is quite a bit more expensive but I like the design and timer functionality and it also claims to be very low retention (and same flat burr diameter).
A timer is useless when single dosing.
If you wanna alternate between coffees on the spot, the G-iota will do a much better job. (I usually have 2 -3 different coffees going on. 1 for milk drinks and 1 or 2 for espresso and pour overs).
If you wanna change between espresso and other brew methods, the G-iota will do a much better job.
Why? Because even with a low retention grinder, there are still beans and bits stuck in between the burrs (if you use a hopper that is). Changing grind settings means purging or running the grinder while adjusting finer.
If you want to single dose with the Mignon XL, I'm not sure I see the advantage of paying almost twice the price for a grinder that's not designed to SD.
I don't know what other burrs are available for the Mignon XL but the DLC burrs are a nice feature in terms of durability but they have quite a classic teeth geometry. No problem for medium-dark roasts though.
Same goes for the stock G-iota's Italmill. The TIN coated have even longer life expectancy I believe.
The fact that you can fit all 3 SSP 64mm burrs on the G-iota is a big advantage for me.
The Mignon XL is a clear winner if you're looking to use a hopper and if you're looling for a long time proven, trustworthy manufacturer. Haven't read anything negative about the G-iota thus far but both companies track records don't compare.
LMWDP #592
Just installed my SSP burrs. They fit perfectly.keifer wrote:others in another thread have also said these burrs look wrong, thanks for that. much easier solution than a bad grinder. I did order the mazzer burrs so they should exchange or accept them back without issue. looks like the right burr is sold out everywhere though unfortunately
This one may interests lots of you here...
I found a funnel that fits perfectly on top of the dosing cup. No more grounds all around my G-iota.
A small addition but a huge difference!
It's a black aluminum 53mm funnel (58mm won't fit). Fits like a glove.
I bought it here: C$ 4.26 30%OFF | Coffee Dosing Ring Aluminum Distributor Handmade Coffee 51/53/54/58mm
https://a.aliexpress.com/_msreqyN
I believe it's also available on Amazon: https://www.amazon.com/dp/B08SBM57GW/re ... FQ07YQQ1NR
LMWDP #592
You bought the 53 or the 58? The 53 mm size of the funnel fits the inside rim of 58 mm portafilter and hence the cup as well? Would have thought the 58 mm funnel would be the one to purchase?
It's the 53mm funnel.
I tried the same model in 58mm as well as a straight wall 58mm funnel and they didn't fit. They're either too tall, too thick or the ID doesn't fit the top of the dosing cup.
The 53mm funnel sits perfectly on top of the cup. There's very minimal play. It doesn't rattle. No more messes around the edges or on your counter top.
LMWDP #592
- GregoryJ
I'll try the one from Amazon, thanks for doing the R&D Jonathan!
GregoryJ wrote:I'll try the one from Amazon, thanks for doing the R&D Jonathan!
domes wrote:Awesome! thank you! Just ordered one.
LMWDP #592
I'm going to be upgrading from a Baratza Vario (54mm ceramic flat burrs), and had already placed a preorder for a Niche to come next month to the US. I'm primarily an espresso-drinker, using my chemex probably like 10% of the time. Preferring the chocolate roasty notes.
Should i go for the DF64 and get the red speed burrs given my situation? Saving money vs a Niche isn't a major concern for me, nor is timing.
Other question is: How serviceable do you think this grinder is vs the niche? I'm liking the fact that I can buy Vario parts directly from their site, and there's a lot of details for them around (including the interesting Vario Alicorn discussion).
