Fiorenzato F4E Nano replacement burrs
Is there anyone who knows if the Mazzer Mini burrs 58 mm will fit a Fiorenzato F4E Nano?
unfortunately dont have a dealer in the countrybas wrote:may I ask why you want to put Mazzer 58 mm burrs in the F4?
I would stick with the stock Italmill and only change for a real improvement. Maybe SSP offers 58 mm as well?
The Mazzer mini manuale with the 58 mm burrs has not a good reputation regarding taste in the cup...
- redbone
I've contacted SSP regarding 58mm burrs.
They stated the smallest burrs they make are 64mm burrs.
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
- redbone
See here http://www.sspgrind.com
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
According to the website https://www.espressoxxl.de/MAHLSCHEIBEN ... NI-MANUALE thay have the same pitch circle diameter 44mm and other dimensions like Fiorenzato 58mm burrs, so I'm pretty sure they will, however not tested personally. If I were you I would take that risk.Sca wrote:Is there anyone who knows if the Mazzer Mini burrs 58 mm will fit a Fiorenzato F4E Nano?
