Fiorenzato F4 E Nano observations - Page 9
- randyr5
Since I got my F4 I've been using without the hopper and just grinding small amounts of beans in the chute. I was using a very cheap aluminum tamper that I had as a weight, but it really wasn't doing the job. I measured the inside of the chute and it is about 57.4mm, so I went on Amazon and bought an inexpensive ($19.50) stainless steel 57mm tamper. It is a perfect fit for the chute.
My brother is a retired machinist and he is going to make me a "chimney" about 2" or so tall to fit over the chute to extend it so it will hold enough beans for my morning shots. The hopper is just way too big for my needs. I will post pics once it's done. Here are a couple of pics of the tamper.
I also ordered Peter's scale and really happy with how it turned out. Peter is awesome to work with and very flexible. I wanted a silver scale that would match my silver super jolly and Peter worked with me to get the color right. He also did an awesome job finding the perfect adjustment ring inner and outer diameter size. Here are some pics
For some reason the last picture is rotated by itself. It's not like that on my phone!
Hi PeterPeter_SVK wrote:Bingo! Do you mean something like this?
<image>
<image>
This is a part of my actual F4E upgrade, however, modification of upper burr carrier is necessary, not only the threads.
How many mm is the tread holes?
Hi Soeren,
I'm not sure what do you mean. Depth of the holes? Hole diameter? Pitch circle diameter?
Threaded holes are M4 (for M4x8 screws), unthreaded blind holes are ca. 3.3mm.
- crazy4espresso
Installed the scale today on my F4. Brilliant instructions! This will give me the finer control of the grind I was looking for. Thanks Peter!!!!
"I would rather suffer with coffee than be senseless." — Napoleon Bonaparte
LMWDP #427
LMWDP #427
- redbone (original poster)
Hansung From SSP anounced that they got many requests for 58 mm burr set.
"Actually it will be avaliable very soon. I am posting it when we are ready."
If there is enough demand and if it makes financial sense we can do a group buy.
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
