Fighting with the Niche Zero for Consistent Extractions - Page 2
I think dialling in by time, rather than taste is generally a bad idea, and +/- 5 sec seems rather normal? So many variables can affect the time, if you keep chasing consistent times and keep changing variables you'll be chasing your own tail.
- GregoryJ (original poster)
Usually the times only change by 1 or 2 seconds once I stop changing the grind. But yes thank you for the advice. If it tastes good I won't worry about the times too much!
Greg can correct me if I'm wrong here, but...namelessone wrote:I think dialling in by time, rather than taste is generally a bad idea, and +/- 5 sec seems rather normal? So many variables can affect the time, if you keep chasing consistent times and keep changing variables you'll be chasing your own tail.
I didn't get the idea he's dialing in by time. I get the idea he's dialing in by taste, and using weight as his means of repeating a successful recipe. With that, time should remain relatively constant. That it was not, and his cup taste wasn't either was merely an indicator to him that he had a problem. At least that's how I read it.
-Peter
LMWDP #553
