Eureka Mignon Single Dose portafilter holder
Hi all!
I have been using Eureka Mignon SD for over six months now with a great results. I have found it easier to grind directly into the portafilter (using a funnel) than into a dosing cup. I only use Eureka's cup to measuring doses. The grinder itself is super fast so holding the portafilter during grinding is not the problem but I'd like to have some portafilter holder such as a fork or some stand on which I could put the PF.
How do you use yours Eureka Mignon SD - with or without a dosing cup? Maybe you have some interesting solutions?
Unless you buy the original fork of the XL, maybe a solution could be to use a tamping stand with a proper height.
