Eureka Helios 80 - manufacturer defect - Page 2
It clumps because there is no clump crusher.jevenator wrote:Looks like you have to grind to flour and that's why it clumps like crazy as well. I wonder why you have to grind so fine?
Some intense WDT should fix it with thin needles though.
The clump crusher is faulty and Eureka acknowledged this.
The clump crusher moves out of the way and essentially becomes non-existent.
I have to grind this fine to extract 30g of coffee from a 20g grind in 28 to 32 seconds.
We tried this at the shop with their slayer machine and it was the same grind fineness.
I posted a video in my original post.Giampiero wrote:Can you post a video while you brew espresso with such grinds setting...i bet the machine get choke or your coffee is in a very stale condition.
My coffee machine doesn't choke.
I don't have one single bean. I use approximately 250 grams a week - a kilogram a month.
I always buy four different coffee types a month and from different roasters.
Nothing is stale.
I am back to my Baratza 270 Wi now and its working fine.
I take it this hasn't been rectified yet by eureka? I was going to buy a helios 65, but can't bring myself to buy based on the issues plaguing the helios 80. I imagine they are the same.
Perhaps this might help:
https://translate.google.com/translate? ... &sandbox=1
Or this: https://www.bellabarista.co.uk/eureka-a ... usher.html
thanks a lot! so if I were to grab the helios and it had some clumping, you think Id be able to install the same clump crusher from the atom? ty
Unfortunately I can't be sure as I've not used a Helios, but I would say that in a number of grinders by the same maker such as Eureka the grind chute is a standardized one and one would think the clump crusher would be too. The only way to be sure I would think though is to write Eureka an email and ask them directly if this clump crusher works.
Was just on Eureka site and they now have a 75mm Helios. Pretty hillarious. To me that says that the 75 burr set used in the Atom, Olympus and Mythos must be better.
OR
The engineers at Eureka are still super duper convinced that you need 20 amps to run a grinder.
(Not sure of the rest of the world but in USA they made the grinder 20 amp when most homes have 15 amp outlets, many dual boiler espresso machines are 20 amp, but they need it, grinders do not).
OR
Since Eureka won't reply, why not contact Bella Barista which sells the clump crusher? They sell both the Helios 80 and the Atom so they probably would be able to figure out whether that clump crusher fits. Here are their various contact infos: https://www.bellabarista.co.uk/contact-bella-barista
ty, will do. I had spoken to my local dealer about it. all they said is "oh you know there are people out there that can find something to complain about every grinder" and they wouldn't say anymore.LewBK wrote:Since Eureka won't reply, why not contact Bella Barista which sells the clump crusher? They sell both the Helios 80 and the Atom so they probably would be able to figure out whether that clump crusher fits. Here are their various contact infos: https://www.bellabarista.co.uk/contact-bella-barista
definite sounds like they backtracked. although not gonna lie, would love to know if you can put ditting sweet lab burrs in the helios 80GeorgeP922 wrote:Was just on Eureka site and they now have a 75mm Helios. Pretty hillarious. To me that says that the 75 burr set used in the Atom, Olympus and Mythos must be better.
