EK43 aligned? - Page 2
- Jake_G
Yowza!
You're welcome!
This would be the case on most burrs, yes. The skirt on pretty much every burr I've ever looked closely at has been a flat plane. I would not expect there to be a slant there.
The process I followed in this case was rather specific to the issue on this grinder. The problem was not the lower carrier, but rather how the upper carrier was positioned in relation to it. To fix it, I made a plug on the lathe that fit into the grinder body in place of the lower carrier bearing. I then mounted the grinder body onto the plug and spun the whole thing up in the lathe and was able to true up the face of the grinder body to the axis of rotation of the lower carrier. This completely corrected the issue without any shims or anything else needed.
Cheers!
deklol wrote:Wow, great info - thanks!
Will this be the case for all burrs? I mean, could it be possible that the last "flat bit" on the teeth are on a slant?
You're welcome!
I'm not sure how you're getting a narrow band all the way around on both burrs. The simplest way to evaluate what a "perfect" wipe would look like is to ink up both burrs and simply line them up on a flat surface outside of the grinder and spin the top burr. Whatever pattern you get on the bench would be what I'd aim for with an alignment process.
My EK43 is aligned to the point where both the stationary and rotary burr produce the same result as your first picture, haven't gotten to the point where I can get it as the second (didn't know it was possible).
Also, very curious to know about your process aligning it - do you use shims? Sanding method? new burr carrier?
Cheers.
Cheers!
LMWDP #704
Thanks for the reply.Jake_G wrote:The process I followed in this case was rather specific to the issue on this grinder. The problem was not the lower carrier, but rather how the upper carrier was positioned in relation to it. To fix it, I made a plug on the lathe that fit into the grinder body in place of the lower carrier bearing. I then mounted the grinder body onto the plug and spun the whole thing up in the lathe and was able to true up the face of the grinder body to the axis of rotation of the lower carrier. This completely corrected the issue without any shims or anything else needed.
Cheers!
Lathe... Is there any way to make this "manually" ? I have seen the "Sanding technique", but that didn't produce the exceptional result you showed.
Cheers
- Jake_G
Nicely done.
Is the stationary burr wiping more cleanly, as well?
LMWDP #704
didn't go there yet... too much other life in the way
and honestly my big old compak is working (wasting a lot of coffee but working)..
hoping to get back to this saga wednesday ish...
- Jake_G
That looks good to me.
How do the shots behave?
LMWDP #704
Saturday. The saga continues.... Funny, I lost so much confidence that I even went back and re-watched the ' how to adjust taste with grind and dose videos'. To see if I had just been labotimized (spelling?) in my sleep.... And my big old conical is just as solid as ever.
So I'm not willing to perturb that again until I have plenty of time to f around....
Stay tuned....
Thanx for all your feedback
Stay tuned....
Hey,
Nice job... Just a thought, I see there are plenty coffee residue in the grinder... these small particles can be thrown around and wipe off paint where the burrs actually are not touching -this has happened to me before and confused the heck out of me many times.
When you have time, I suggest you wipe it as clean as possible in the grinding chamber and then look at the results
Cheers.
Cheers.
