Ditting vs Bunn Grinders - Page 3
JohnB.
#21: Post by JohnB. »
For my Hario 5C Syphon I add 38.5g of beans & get 38.1G-38.2g back. What doesn't come out with the initial grinding will drop out later if you run the grinder briefly & hit the flap lever a few times. It's an extremely easy grinder to clean as a standard vac nozzle fits right into the hopper feed hole plus the entire adjustment assy./outer burr carrier comes out after removing 2 screws. If you are doing bulk grinding it still puts out 1lb every 30 seconds with the Ditting burrs.
LMWDP 267
zombiecoffee
Supporter
#22: Post by zombiecoffee »
I am just tacking this onto thread instead of creating a new post since it pertains to the discussion on page 2.
"restaurant parts" sells the Bunn G 27 detent plate and the new sticker for the dial http://www.partstown.com/
BU11075.0100 Decal $8.30
BU11067.0001 Detent Plate $5.10
using THANKS9 got the shipping and handling down to $9.
these are for the Bunn g2 trifecta and fit all the g's.
Anyone can turn green beans brown...
Chabeau
#23: Post by Chabeau »
Thanks for the info Kurt.
Where did you guys pick up your 804 burrs? There are a couple places online but I'm just not sure which one to choose.
Thanks
"The percolations are imminent."
-C.M. Burns, c.1996
JohnB.
#24: Post by JohnB. »
Mine came directly from Ditting USA. If you buy online make sure you are getting the newer "machined" burrs & not the older pressed style which I believe is still available.
LMWDP 267
