Ceado E37S - seems to have a switch problem
I have a fairly new Ceado E37S. I absolutely love it, but I'm starting to have problems with the pushbutton switch that sharts the grinder. The button the portafilter presses on. Sometimes when I push the portafilter in to start the grind, the grinder makes a clicking sound and the timer counts down. Or after I finish a grind after I pull the portafilter back it starts counting down again and making that clicking sound. It's definitely not jammed-otherwise that second scenario I described would not occur. I'm guessing it's a faulty switch but I suppose it may be a firmware issue too.
Has anyone else had this problem? And if so, is it an easy fix? I don't mind wrenching on a grinder, up to a certain point.
- Jeff
It is potentially the motor capacitor as another part that might be the root cause.
- cafeIKE
It could also be a faulty connection that allows the counter but not the motor to run.
Or a driver chip
Or a bad solder joint
Or ???
Best get it looked at pronto... before all the smoke gets out.
Or a driver chip
Or ???
Ian's Coffee Stuff
