Bunnzilla for Dummies - Bunn LPG upgrade to Ditting 804 burrs - Page 2
- JohnB.
The LPG is too small to be a Bunnzilla. You'll have to dream up your own name for that one.
LMWDP 267
- drgary
Suggestions anyone? BunnDitt?
LMWDP#308
LMWDP#308
- JohnB.
Son of Bunnzilla? http://en.wikipedia.org/wiki/Son_of_Godzilla
LMWDP 267
- beer&mathematics
BunnDitto!drgary wrote:Suggestions anyone? BunnDitt?
LMWDP #431
- doubleOsoul
Is this upgrade only for the Bunn LPG series?
Oops... I see it also includes G series which is what I have.
www.soulsidecoffee.com LMWDP #354
- drgary
I looked up "Bunnzilla" in the official H-B dictionary and it defines Bunnzilla as "any Bunn grinder that has been hot rodded." And if you think it's small, my wife looked at it yesterday and called it a "monstrosity" on our counter until I showed how it just fits under the cabinets. Actually let's keep the name as is so people can look up the Frankenmachine version of a Bunn grinder, okay? Bunnyzilla would have been a bit silly anyway ...JohnB. wrote:The LPG is too small to be a Bunnzilla. You'll have to dream up your own name for that one.
Back on topic.
LMWDP#308
LMWDP#308
- TomC
I would have practically given you my LPG. I've been listing it on CL on and off for months. Heck, I'd let it walk for only $100. I only paid barely that and spent a ton of spare time polishing out the plexi that had been repeatedly scoured with a scrubby, hazing the plexi. It's sat unused since I cleaned it up, nearly 2 years ago. The plexi is now perfect too. It just needs new burrs unless you only grind auto-drip. It's dead on consistent at only one very fine setting.
Anyways, these really never grow out of the bulk coffee grinding camp, due to the terrible pop-corning issues. I've considered various tubes or rigged up methods to keep the beans somewhat over the burr path, but there'd still need to be a way to sweep beans all the way down to the burrs that refuse to fall in.
- JohnB.
That H-B dictionary seems to be about as accurate as Wikipedia. Bunnzilla is what I named my modified G3 lets not bastardize the name.drgary wrote:I looked up "Bunnzilla" in the official H-B dictionary and it defines Bunnzilla as "any Bunn grinder that has been hot rodded."
LMWDP 267
- JohnB.
doubleOsoul wrote:Is this upgrade only for the Bunn LPG series?
The original mod I came up with was for the G series Bunn grinder & included making the adjustment stepless along with the Ditting machined burr swap. With the new G2 Trifecta detent plate w/27 factory settings that's now available for a couple dollars the stepless conversion is no longer necessary. The G series Bunn is the ideal candidate as it's auger feed eliminates popcorning which is an issue with the LPG when single dosing. Also the G series allows easy grind adjustment compared to the LPG which uses a screw adjustment under? the grinder.
LMWDP 267
For this high degree of cleverness and ingenuity, including the unforgettable name, we heartily salute you.JohnB. wrote:The original mod I came up with was for the G series Bunn grinder & included making the adjustment stepless along with the Ditting machined burr swap. With the new G2 Trifecta detent plate w/27 factory settings that's now available for a couple dollars the stepless conversion is no longer necessary. The G series Bunn is the ideal candidate as it's auger feed eliminates popcorning which is an issue with the LPG when single dosing. Also the G series allows easy grind adjustment compared to the LPG which uses a screw adjustment under? the grinder.
I couldn't be happier with mine. Thank you for your guidance.
