BUNN GVH-1
- redbone
New BUNN GVH-1, 120V -Visual Hopper Grinder- 1lb, 2lb or 3lb.
http://www.bunn.com/coffee-grinders
Specs: https://catalog.bunn.com/public/docs/00 ... 0.0100.PDF
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
"340° dial resolution for precise tuning of grind particle size"
Assuming the grinder has the same particle size range as the G-1 does this mean that the pitch of the adustment screw is about twice as fine as the 180 degree adjustment on the G-1? If so (and assuming this can be retrofitted to the G-1 model) perhaps this will allow enough fine gradiation in the espresso range to use without the fine adjustment screw mod.
- [creative nickname]
That is cool to see! Hopefully they haven't made any internal changes that make retrofitting a Ditting 804 burrset harder than it is on a G-series grinder...
LMWDP #435
- redbone (original poster)
Looked up size and weight of machine and did some comparisons. Real difference in depth in weight vs popular Eureka 75mm burr grinders.
BUNN GV-1
Height 65.5 cm
Width 29.2 cm
Depth 40.1 cm
Weight 25.492 kg
BUNN G1
Height 57.9 cm
Width 18.5 cm
Depth 40.6 cm
Weight 25.492 kg
ATOM SPECIALITY 75
Height 57.0 cm
Width 18.0 cm
Depth 22.7 cm
Weight 9,5 kg
Olympus 75E
Height 63.7 cm
Width 24.0 cm
Depth 27.5 cm
Weight 13 kg
BUNN GV-1
Height 65.5 cm
Width 29.2 cm
Depth 40.1 cm
Weight 25.492 kg
BUNN G1
Height 57.9 cm
Width 18.5 cm
Depth 40.6 cm
Weight 25.492 kg
ATOM SPECIALITY 75
Height 57.0 cm
Width 18.0 cm
Depth 22.7 cm
Weight 9,5 kg
Olympus 75E
Height 63.7 cm
Width 24.0 cm
Depth 27.5 cm
Weight 13 kg
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
The pictures of the burrs look just like the older ones so I assume popping in SSP burrs will be simple. But checking burr P/Ns will probably give you a better idea.
Ira
Ira
There seems to be some kind of clamp on there too. Would be interesting, just like the adjustment assembly, if that could be retrofitted. My Bunnzilla would appreciate it.
