Baratza Vario Macro-Micro Setting Overlap & Primary Calibration Method
FYI I just changed my Vario burrs from ceramic to steel (as I'm doing more pour over than espresso these days, but still use it for both).
Two interesting points:
1) I recalibrated it so it so the steel burrs start to touch at 2Q, by moving the 2.5 mm "primary calibration" screw/slot all the way back (as far as it would go), with the 2 mm "secondary" calibration screw removed completely. Then I screwed the 2 mm "primary" adjustment screw back in so it just touches; my thought is this would provide a better support for the bottom grind chamber (vs using the 2 mm adjustment screw to push up the chamber all by itself). I'm not sure it makes a difference, but I feel better about it.
2) And when checking the touch points, I found that yes, it just starts to touch at 2Q, but also at 3G! They make the exact same burr-starting-to-touch sound at 2Q & 3G, so a grind setting of 2Q=3G. Seems of the 23 micro settings (A-W), only 10 are unique (A-J). If this is the case through-out the range, then for example, 2K=3A, 2W=3M, etc. And 2U=3K=4A. So instead of us having 23 (micro) X 10 (macro) = 230 settings, you only have 113 unique settings (if you lay them out in Excel). Does this matter, not really I guess, still love the grinder, although I find it interesting; and knowing this explains how to better use the grind settings.
Here's the overlap between grind setting 2 (fist column) and 3 (second column):
2 3
A _
B _
C _
D _
E _
F _
G _
H _
I _
J _
K A
L B
M C
N D
O E
P F
Q G
R H
S I
T J
U K
V L
W M
_ N
_ O
_ P
_ Q
_ R
_ S
_ T
_ U
_ V
_ W
2 3
A _
B _
C _
D _
E _
F _
G _
H _
I _
J _
K A
L B
M C
N D
O E
P F
Q G
R H
S I
T J
U K
V L
W M
_ N
_ O
_ P
_ Q
_ R
_ S
_ T
_ U
_ V
_ W
- Jeff
Half overlap makes sense. Doing so would let you dial in coarse with fine in the middle, then just use fine and be able to reach the "rejected" coarse step.
Good point; yes, otherwise you could get caught between macro setting.
Along those lines, 1 macro change = 10 micro changes (say gong from 3M to 2M, but 2M=3C, and 10 micro changes between 3M and 3C). As there are 23 micro changes (A-W), 1 macro change is less than half a full range micro changes (10 of 23)). This supports your point of not being in a position to get stuck between macro changes.
Has anyone else checked to see where their burrs start to touch in two adjacent macro settings? Like where they start to touch in macro 2 vs. macro 3 (or macro 1 vs macro 2, etc.) to see if they are getting the same overlap findings?
So would this work the same for Macro 1 Micro R equalling Macro 2 Micro H? For WHATEVER the reason, with a lot of my blends, it seems like I prefer Macro 1 because I have more room to "play" with the micro settings if say, it flows out too fast on 1R (which is what I have it at now), I can always set the Micro to P or Q, and still have so much room to play with. I used to use Macro 2, but on these same blends--I was up to D at times with the Micro, and still not fine enough at times. Yes, that is with recalibrating.
Yes, but see the excellent info in Jake_G's Oct 10, 2020 replay in "Baratza Vario - grind size by steps."
Basically Jake_G is saying the closer you are to the top of the micro adjustment, the smaller the micro step, so you should be able to better dial in espresso using say macro 2 & micros A-E, vs. macro 1 & micros K-O (assuming you can get fine enough at macro 2 & micro A).
that's really interesting, I've never knew how it overlapped (or bothered to figured it out) but it makes sense. if the overlap starts at K then 3K would be the same as 4A, 4K the same as 5A and so on... all documentation I can find says the unit has 230 grind settings and markets it more like after 2W the next step is 3A. the overlap, as mentioned in the OP, puts it more at 113 steps but I suppose 2U, 3K and 4A probably still have fine differences and are not exactly the same.Kz1000p wrote:Here's the overlap between grind setting 2 (fist column) and 3 (second column):...
I wrapped it in a code tag which keeps a fixed-width font and makes it easier to read
1A
1B
1C
1D
1E
1F
1G
1H
1I
1J
1K 2A
1L 2B
1M 2C
1N 2D
1O 2E
1P 2F
1Q 2G
1R 2H
1S 2I
1T 2J
1U 2K 3A
1V 2L 3B
1W 2M 3C
2N 3D
2O 3E
2P 3F
2Q 3G
2R 3H
2S 3I
2T 3J
2U 3K 4A
2V 3L 4B
2W 3M 4C
3N 4D
3O 4E
3P 4F
3Q 4G
3R 4H
3S 4I
3T 4J
3U 4K 5A
3V 4L 5B
3W 4M 5C
4N 5D
4O 5E
4P 5F
4Q 5G
4R 5H
4S 5I
4T 5J
4U 5K 6A
4V 5L 6B
4W 5M 6C
5N 6D
5O 6E
5P 6F
5Q 6G
5R 6H
5S 6I
5T 6J
5U 6K 7A
5V 6L 7B
5W 6M 7C
6N 7D
6O 7E
6P 7F
6Q 7G
6R 7H
6S 7I
6T 7J
6U 7K 8A
6V 7L 8B
6W 7M 8C
7N 8D
7O 8E
7P 8F
7Q 8G
7R 8H
7S 8I
7T 8J
7U 8K 9A
7V 8L 9B
7W 8M 9C
8N 9D
8O 9E
8P 9F
8Q 9G
8R 9H
8S 9I
8T 9J
8U 9K 10A
8V 9L 10B
8W 9M 10C
9N 10D
9O 10E
9P 10F
9Q 10G
9R 10H
9S 10I
9T 10J
9U 10K
9V 10L
9W 10M
10N
10O
10P
10Q
10R
10S
10T
10U
10V
10W
