Baratza single dose hopper
Baratza has come out with a single dose hopper. It doesn't seem to have any system to weigh down the beans like the Orphan hoppers. I usually dose the grinder for the day's expected use so this is an easy way to try single dosing. I ordered one and will report back.
I've just ordered a 3D printed hopper for the Vario. Has an interesting auger setup to feed the beans at an acceptable rate into the burr chamber to reduce popcorning. The pics on the site are currently for a Sette but they will be updating the photos shortly.
https://www.etsy.com/ca/listing/9493485 ... or-baratza
After using the Baratza single dosing hopper for a few days here are my thoughts. Basically the inside of the hopper looks the same as the regular hopper with the little "anti kickback" disk on three little legs -- so no weight possible as the OE hoppers have. Retention in the grinder seems minimal, but I do run it until empty and rock it a bit to clear the grounds. I previously removed the portafilter holder so as to give the ground beans a clearer path and to make room for the OE portafilter funnel that I use. The grind seems to require a slight adjustment, I assume because there is no pressure from the quantity of beans in the hopper. All in all it's a reasonable way to try single dosing, although one could do it with the regular hopper, and I'm not sure the result would be much different, but for $24 why not?
You can just use the lid of the hopper as a bellows by moving it up and down after grinding.
